Re: 90 degree oil filter adaptor question [Re: dan9] #1711519
12/27/14 09:21 PM
12/27/14 09:21 PM
I found a piece of rtv lodged in the pick-up tube.
I thought that was it
Re: 90 degree oil filter adaptor question [Re: RapidRobert] #1711520
12/27/14 09:52 PM
12/27/14 09:52 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
He must have found a full tube of RTV in the pick up tube. Unless it was a giant gob of RTV that closed off the p/u tube , it should have disintegrated when it hit the pump. And how did a giant piece of RTV get past the screen on the sump. And where did 60 PSI come from with the P/U tube closed off ?
Re: 90 degree oil filter adaptor question [Re: mopar_man] #1711521
12/27/14 10:00 PM
12/27/14 10:00 PM
Yes we need clarification
Re: 90 degree oil filter adaptor question [Re: RapidRobert] #1711522
12/28/14 09:03 PM
12/28/14 09:03 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
I appreciate all the suggestions and you guys are right. There was more to the problem than a piece of rtv. I will try to post the pic of the pick-up screen. If it doesn't post suffice it to say the screen was not checked or cleaned before assembly. It will be now.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711523
12/31/14 03:51 PM
12/31/14 03:51 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Wow!!! yikes...has "oil starvation" written all over it...damn...that's a tough lesson...
Re: 90 degree oil filter adaptor question [Re: Diplomat360] #1711524
01/12/15 02:17 AM
01/12/15 02:17 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
yeah, we all learn these tough lessons as part of learning. I had the big center bolt loosen on my 90* adapter on my 340 once. Lost a bunch of oil running down the road, and had forgotten to plug the idiot light onto the oil sending unit. Didn't know I was loosing oil until the lifters started talking, & then I saw the smoke screen in the rear view mirror. I got off lucky just toasting all the bearings in the fresh engine. Had to pull & clean and inspect every thing. Got the big center bolt tight the 2nd time!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 90 degree oil filter adaptor question [Re: Diplomat360] #1711525
01/12/15 11:31 AM
01/12/15 11:31 AM
scratchnfotraction Offline
I got a van 318 that looks like that pick up screen. the screen was close to a match also.
this engine would pump oil up top then starve for oil at the pump due to not returning the oil to the pan fast enough.
shut it down and wait 10 mins, it would drain back to the pan. fire it up it would have oil psi then fall off to 0 again.
same thing, bearings were toast and pump chewed up from carbon chunks.
good luck with the new bearings
Re: 90 degree oil filter adaptor question [Re: scratchnfotraction] #1711526
01/12/15 01:37 PM
01/12/15 01:37 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thanks, new bearings should be here today. Crank and rods are ready.
