Page 3 of 5 1 2 3 4 5
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711390
12/18/14 03:29 AM
12/18/14 03:29 AM
SoCal
Brian Hafliger Offline
SoCal
My Duster's getting nothing but the best...RMS AlterKtion! My helper agrees, it's the best setup out there!
Re: Magnum force suspension wtf! [Re: Brian Hafliger] #1711391
12/18/14 03:38 AM
12/18/14 03:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have no complaints about my Comp Chassis piece.... and it doesn't have those gawd awful rails protruding into the engine compartment as seen with the Alter K. Header builder complimented that feature... Mike only does them "in house" and they are a "race" piece where the Alter K does have it's street attributes.
Re: Magnum force suspension wtf! [Re: Brian Hafliger] #1711392
12/18/14 09:28 AM
12/18/14 09:28 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I am sorry I just don't care for square tubing, don't think it looks nice.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711393
12/18/14 12:02 PM
12/18/14 12:02 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
hands down the alterkation in my opinion is the best. strong enough for the street and engineered for race car speeds.
It fits onto the stock square frame rails seamlesly and leaves the most room of any of them for the engine. also made my belly pan fit easier. Did i mention how stable my car is at....?
and that my car sits looooow
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Magnum force suspension wtf! [Re: bigtimeauto] #1711394
12/18/14 12:11 PM
12/18/14 12:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I agree but even the round-tube style have so many little gussets welded in they look like a giant spider web!
The problem is the bottom of the frame rails aren't flat so they can't just lay a piece against it. And the LCA would likely hit on compression. So they end up having to put all those intrusive pieces in the engine compartment.
Re: Magnum force suspension wtf! [Re: bigtimeauto] #1711395
12/18/14 01:44 PM
12/18/14 01:44 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Where are those inner fender panels? Looks like a baby pro mod!
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711396
12/18/14 02:58 PM
12/18/14 02:58 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Here's a shot of the MF kit under my 1964 HEMI Dodge. No issues with installation and driveability was good.
Re: Magnum force suspension wtf! [Re: Mopar_Rich] #1711397
12/18/14 02:59 PM
12/18/14 02:59 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I did brace the shock towers.
Re: Magnum force suspension wtf! [Re: Mopar_Rich] #1711398
12/18/14 03:04 PM
12/18/14 03:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good, note to op you can see his LCA is bent too. All of them I have seen are bent there. The biggest problem I see with your is the steering rack and tie rods.
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711399
12/18/14 03:11 PM
12/18/14 03:11 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
This pic was taken on a lift, so when it was down on the ground the tie rods ends were horizontal. No bump-steer to speak of.
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711400
12/18/14 03:36 PM
12/18/14 03:36 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
I never questioned the lower arm?
Did some work on it today...
Milled the mounts on the r&p to move it to the rear about .4". Things improved but not good. So next is to move the lower arms alittle forward (only very little possible) and grind a small notch to move the r&p downwards (again only a small amount) then install adj steering stops and finally mill the upper shock mounts to decrease downward travel.
I think that that together will work.
Might still rub the dust boots but that i can live with.
As far as for track width im thinking of milling the mounting surface of the wheels and the hubs. About 1/8" on both.
Maybe that will be enough...
Re: Magnum force suspension wtf! [Re: Mopar_Rich] #1711401
12/18/14 08:12 PM
12/18/14 08:12 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
No the op has cut and welded or bent tie rod rack situation going on. Yours looks good, have always like the look of MF front ends. Heard to many bad stories to give them a try.
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711402
12/18/14 08:17 PM
12/18/14 08:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure the OP had his tie rods bend on a full turn..
the rack ball bottomed out and bent... even looking
at the pic he showed it looks bottomed out(angle)
Re: Magnum force suspension wtf! [Re: MR_P_BODY] #1711403
12/18/14 09:21 PM
12/18/14 09:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
To me, it seems like his steering arm is changed causing the interference problems. Hard to see with these pics.
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711404
12/19/14 01:34 AM
12/19/14 01:34 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I'm w Bigtime on this one 100%,the only thing I want to add is Santuffs like his Dart...Bobby any part # ?
Re: Magnum force suspension wtf! [Re: fishy340] #1711405
12/19/14 01:48 AM
12/19/14 01:48 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
RMS
Re: Magnum force suspension wtf! [Re: demon440] #1711406
12/19/14 01:51 AM
12/19/14 01:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Hemi Denny FTW.....
Mopar to the bone!!!
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711407
12/19/14 04:55 AM
12/19/14 04:55 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Baby pro mod...with a windshield wiper motor...lol!!
Re: Magnum force suspension wtf! [Re: cudadoug] #1711408
12/19/14 08:53 AM
12/19/14 08:53 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Oh sorry should have said outlaw 10.5 car as they have smoothed factory fire walls. Do like the aftermarket steering column and race brakes and no radiator in front of car!
Re: Magnum force suspension wtf! [Re: 1967dartgt] #1711409
12/19/14 11:16 AM
12/19/14 11:16 AM
Canada
onig Offline
onig  Offline
Canada
Hey BigTime, can you post a pic of your engine bay in race trim?
69 Dart
