R3 block timing cover crank seal Part # ?? #1711161
12/15/14 09:09 PM
12/15/14 09:09 PM
HR3128 Offline OP
HR3128  Offline OP
Anyone have a part number a low deck R3 block front cover crankshaft seal? The seal that was included with the cover I bought does not fit. It's about .030" to big.
What should the ID be for the cover cutout?
Thanks.
Re: R3 block timing cover crank seal Part # ?? [Re: HR3128] #1711162
12/15/14 09:28 PM
12/15/14 09:28 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Need more information.
Are you running a chain?
Re: R3 block timing cover crank seal Part # ?? [Re: Leon441] #1711163
12/15/14 10:32 PM
12/15/14 10:32 PM
HR3128 Offline OP
HR3128  Offline OP
It's a chain. Cover part number is P4876632.
I bought this one off ebay. I either have to get a different seal or re-machine the cover.
It is an R3 low deck.
Re: R3 block timing cover crank seal Part # ?? [Re: HR3128] #1711164
12/15/14 11:19 PM
12/15/14 11:19 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Check on a stock front seal for a 340. I have a arrow frt cover on a 9.200 r3. A stock seal worked.
Re: R3 block timing cover crank seal Part # ?? [Re: rickraw] #1711165
12/16/14 02:29 AM
12/16/14 02:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
It's this cover and it takes the standard seal, like the MP P4867280.
