Safe method for removing old radiator paint #1711130
12/15/14 07:34 PM
12/15/14 07:34 PM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
I had to remove my radiator from the '68 Dodge for leak repair. Now, before I put it back in, I want to remove the old chipping paint and respray it (both tanks and core). I was going to use a brush on paint stripper, wait for the paint to start bubbling and then hose off. My question is: Will the paint stripper harm/cause leaks for my radiator? Is there a better/safer method one person can do around the shop to remove the old paint or is this OK?
Re: Safe method for removing old radiator paint [Re: moparjo68] #1711131
12/16/14 11:10 AM
12/16/14 11:10 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I would get someone to vat it. It is the only way to get all the paint off of the core fins.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Safe method for removing old radiator paint [Re: MOPARMIKE69] #1711132
12/16/14 01:33 PM
12/16/14 01:33 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I have soda blasted tanks with good results
Re: Safe method for removing old radiator paint [Re: moparjo68] #1711133
12/16/14 05:28 PM
12/16/14 05:28 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Take it to a radiator shop!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Safe method for removing old radiator paint [Re: moparjo68] #1711134
12/21/14 12:30 AM
12/21/14 12:30 AM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
Don't use paint stripper or you will have a royal mess trying to get it all off. Any residue left behind will ruin attempts to paint it.
I've had excellent results sealing all openings and (glass) bead blasting them lightly. Then blow it really clean and spray a coat of black epoxy primer on it. When the epoxy has dried, apply the black color coat within the re-coat window. Usually you have between an hour and a couple of days minimum.
