T-Chain Tensioner Question?? #1709698
12/11/14 10:43 PM
12/11/14 10:43 PM
Holly/MI
Dean_Kuzluzski Offline OP
Holly/MI
These two parts look the same, just not a good thorough definition of applications?? Isn't a 3.9 a cut down LA motor to 6 cylinder? So, T-chain and components would be common?
See below.....
http://www.summitracing.com/parts/dcc-5007709
http://www.summitracing.com/parts/clo-9-5387
Re: T-Chain Tensioner Question?? [Re: Dean_Kuzluzski] #1709699
12/11/14 11:56 PM
12/11/14 11:56 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I would say they are the same. That said, I will never use one again. When I built my 416 put one in it. Used a 590 solid cam with springs set @ 185 on the seat and 380 open.
Lost the cam with just over 200 runs on the motor. When we rebuilt the cam bearings were wore smooth out. The front being the worst. JMO
Re: T-Chain Tensioner Question?? [Re: Dean_Kuzluzski] #1709700
12/11/14 11:57 PM
12/11/14 11:57 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Yes they will work on both applications. They were introduced to eliminate the common timing chain rattle on 3.9 engines but work just the same on a v8 LA or magnum.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: T-Chain Tensioner Question?? [Re: Dean_Kuzluzski] #1709701
12/12/14 12:35 AM
12/12/14 12:35 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
rick e. sells them, on the forum here. i'm thinking they're somewhere around 25 bucks?
Re: T-Chain Tensioner Question?? [Re: rt66jim] #1709702
12/12/14 12:56 PM
12/12/14 12:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO more trouble than they are worth.
Re: T-Chain Tensioner Question?? [Re: Challenger 1] #1709703
12/12/14 03:24 PM
12/12/14 03:24 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Same parts, yes. Use them on all the small blocks I do. Never had a failure or issue from a one of them. One of the better $30 spends you can make for a small block.
Re: T-Chain Tensioner Question?? [Re: moper] #1709704
12/12/14 03:51 PM
12/12/14 03:51 PM
dogdays Offline
dogdays  Offline
I couldn't get the timing chain on with mine when engine was going together. After 10K miles, there was enough slack in the chain for it to work.
There's a reason that many foreign engines use chain tensioners. On the other hand, overhead cams use much longer chains.
I don't think the small amount of extra force exerted on the end of the camshaft will wear out the bearing, but it's the most visible thing so easy to blame.
R.
Re: T-Chain Tensioner Question?? [Re: dogdays] #1709705
12/12/14 03:54 PM
12/12/14 03:54 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Running one on my LA360. Easy install and no problems in eight years of it being together.
