Re: T-Chain Tensioner Question??
[Re: rt66jim]
#1709702
12/12/14 12:56 PM
12/12/14 12:56 PM
Challenger 1
Cincinnati, Ohio
I would say they are the same. That said, I will never use one again. When I built my 416 put one in it. Used a 590 solid cam with springs set @ 185 on the seat and 380 open. Lost the cam with just over 200 runs on the motor. When we rebuilt the cam bearings were wore smooth out. The front being the worst. JMO
IMO more trouble than they are worth.
[Re: Challenger 1]
#1709703
12/12/14 03:24 PM
12/12/14 03:24 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Same parts, yes. Use them on all the small blocks I do. Never had a failure or issue from a one of them. One of the better $30 spends you can make for a small block.
[Re: dogdays]
#1709705
12/12/14 03:54 PM
12/12/14 03:54 PM
Posts: 4,449 Michigan
MarkZ
Worthy
Worthy
Running one on my LA360. Easy install and no problems in eight years of it being together.
