Re: E-85 fuel [Re: 440Jim] #1709630
12/14/14 01:48 AM
12/14/14 01:48 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
440 w/ Ross forged flat top pistons, zero deck. 4.35" bore, 3.75" stroke, 6.76" Eagle rods. Aluminum Eddy RPM heads, 75cc chambers polished. With 0.039" head gasket it all calculates to about 11.25:1. Cam is Ultradyne flat tappet solid. Lash 0.016" hot. Cam card picture attached. I used a degree wheel and verified, cam is installed per the card. Intake is Mopar P3690982 converted to port EFI (Weiand six pack tunnel ram).
With iron heads, eddy RPM intake, and a carb at just over 10:1 I was able to run on 93 octane fuel.
Everything I have read so far says I will probably have to run higher octane now. My fuel system can easily handle the flow requirements for E-85, the only thing I would have to do is up the injector sizing.
The way I see it is I have these options:
1) Race gas / race gas blend / or some sort of octane boost
2) E-85
3) Bigger cam
4) Thicker head gasket
Anyone profess to know enough about this to know for sure that I can not run pump gas with this engine? There is a gas station 1 mile from my house that has E-85, but, if I drive any great distance it may be hard to always find it. Running cooler would be a nice benefit, it does get quite hot here in Texas in the summer. I am tempted to go a little bigger on the cam as it is, the springs installed are good to about 0.600". I would be interested in opinions regarding the correct cam sizing to match this intake. Car is manual transmission, so stall speed is not going to be an issue. Rear axle is 3.90 and the car is a '68 Barracuda.
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: E-85 fuel [Re: 68cuda440] #1709631
12/14/14 01:49 AM
12/14/14 01:49 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Intake manifold...
-Michael
Re: E-85 fuel [Re: 68cuda440] #1709632
12/14/14 01:53 AM
12/14/14 01:53 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Your chambers are ALOT more efficient than the iron heads were for sure. But it will still be on the edge with pump IMO. ANother thing I found out in my old BB the detonation got worse when I went from auto to manual.
Mopar to the bone!!!
Re: E-85 fuel [Re: 72Swinger] #1709633
12/14/14 01:58 AM
12/14/14 01:58 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Of course... the converter softens the load at lower rpm. But, did not think of that. Yes, also switching from auto to manual, I did not think of that variable.
-Michael
Re: E-85 fuel [Re: 72Swinger] #1709634
12/14/14 02:07 AM
12/14/14 02:07 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Well the ECU can take switch inputs for multiple tunes, I think up to 4 versions. If it will eek by with pump gas and maybe a bottle of octane boost for road trips when I can't get the "good stuff" I can live with that option. Then, for cruising local and the track I can fill it up with E-85 and throw the switch! Tank is about 32 gallons and has a built in sump with an in tank Aeromotive pump. I designed the fuel system with the E-85 option in mind.
-Michael
Re: E-85 fuel [Re: 68cuda440] #1709635
12/14/14 02:08 AM
12/14/14 02:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
2) E-85
3) Bigger cam
-Michael
I'm running higher compression than you are on my
SB with iron heads at the moment with a 260/270 @ 50
cam... on the street I run 87 octane.... mine is 10.4
EDIT
I see you say its 11.2... with 93 and alum heads
I'd run it... E-85 would do it easy but its only E-85
during the summer months
Re: E-85 fuel [Re: MR_P_BODY] #1709636
12/14/14 02:18 AM
12/14/14 02:18 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Sorry boss, don't understand what you mean by 10.4?
With 260 @ 50 you definitely have a larger cam and your intake closes later than mine and bleeds off some pressure at the lower RPMs. I can't imagine driving the car in your signature on the street, that must be interesting.
-Michael
Re: E-85 fuel [Re: 68cuda440] #1709637
12/14/14 02:24 AM
12/14/14 02:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With 260 @ 50 you definitely have a larger cam and you intake closes later than mine and bleeds off some pressure at the lower RPMs. I can't imagine driving the car in your signature on the street, that must be interesting.
-Michael
No not that car... my Rampage is 10.4 compression
with iron heads
Re: E-85 fuel [Re: MR_P_BODY] #1709638
12/14/14 02:32 AM
12/14/14 02:32 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
with iron heads
Wow, you had me going there... and in the back of my mind I was thinking "when did they ever make a W9 in iron, OK... don't know everything, maybe they did."
There is so much information and misinformation out there on this topic. I read one place where they say you can go up 1 full point when going from iron to alum w/ no drawback, then I read that DCR is the key, and it makes no difference if the head is iron or not. Then there are folks swearing they run higher than the "recommended" 8.3 DRC because they have better heads and flat top pistons with good quench. The number of opinions on the topic seems infinite. And then add in whose DCR calculation method is correct, and what number to actual use, and, then, of course if it is a solid lifter cam it is different and lash comes into play. Of course altitude here is 675 feet above sea level... that matters also. Just in case... car is painted dark green.
-Michael
Re: E-85 fuel [Re: 68cuda440] #1709639
12/14/14 02:47 AM
12/14/14 02:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
with iron heads
-Michael
Well I agree with the full point of comp with alum
heads.. also your altitude is low and one other thing..
if you keep the engine cooler it helps also... JMO
but 11.25 and alum head 625 altitude on 93.. I'd run it
Re: E-85 fuel [Re: MR_P_BODY] #1709640
12/15/14 11:40 PM
12/15/14 11:40 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have only run 93 octane in my small block and I have had no problems so far. It is 10.9 com. with aluminum heads. Cam is 255/266 @.050. Cranking cylinder pressure is 190-200.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: E-85 fuel [Re: D-50] #1709641
12/17/14 01:00 AM
12/17/14 01:00 AM
Texas
Steve Reynolds Offline OP
Texas
So, I have lots of good information as always, & I thank you all. The 440 has a 1050 dominator with 92 jets, what needs to be done to it for E-85 compatibility, I think the rest of the fuel system will be ok?
Steve
Re: E-85 fuel [Re: Steve Reynolds] #1709642
12/17/14 07:02 AM
12/17/14 07:02 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I run what I have with E85, and just keep an eye on things. Purchasing new parts I tend to choose those saying themselves to be E85-compatible. Smaller bits and pieces used in my home-built fuel system I drop one identical part in a glass jar with E85 and just leave it there for the next few years, to see if anything is affected.
For getting the correct jetting I recommend you to have a look at the Innovate MTX-L or corresponding...you won't regret it.
For shooting in the dark you can use +30% flow as guideline...
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: E-85 fuel [Re: Steve Reynolds] #1709643
12/17/14 10:44 AM
12/17/14 10:44 AM
PA
ajcasini Offline
ajcasini  Offline
PA
Steve to make it happy on e85 you would need:
Boosters
Metering Blocks
Air Bleed Change
Needle and seat change
Squirter change
Possibly floats if has plastic or brass.
Re: E-85 fuel [Re: ajcasini] #1709644
12/17/14 11:07 AM
12/17/14 11:07 AM
Texas
Texas
Thank you again for all the information & advice, now I just need to make it happen.
Steve
Re: E-85 fuel [Re: ajcasini] #1709645
12/17/14 02:20 PM
12/17/14 02:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Boosters
Metering Blocks
Air Bleed Change
Squirter change
just make it easy and contact thie guy ^
Re: E-85 fuel [Re: Quicktree] #1709646
12/17/14 02:25 PM
12/17/14 02:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Boosters
Metering Blocks
Air Bleed Change
Squirter change
Steve.. just send your carb to AJ and let him fix it
up... it will save you a lot of time... and maybe a engine
