Page 2 of 3 1 2 3
Re: what gains did you find with dry sump? [Re: RT540] #1708632
12/11/14 06:27 PM
12/11/14 06:27 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Autoverdi pump
Re: what gains did you find with dry sump? [Re: RT540] #1708633
12/11/14 06:29 PM
12/11/14 06:29 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Tank
Re: what gains did you find with dry sump? [Re: 572_dup2] #1708634
12/11/14 06:39 PM
12/11/14 06:39 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Find any power or see any e.t difference? If you were using vacuum pump did you remove it?
I've been using a drysump system for better than 15 years...can't say I saw any et. Differance at all, but the biggest single thing that sold me was having oil psi. In the shut down area... Other advantages as talked about above we're easy priming of the oil system, cooler oil with volume , oil with less air intrained in it... As far as taking the vacuum pump off... My motor pulls 17" of vacuum with both the oil pump and vacuum pump... Take the belt off the vacuum pump the the motor drops to 8" of vacuum and looses 25 hp.
Re: what gains did you find with dry sump? [Re: boatracer572] #1708635
12/11/14 11:20 PM
12/11/14 11:20 PM
Jerry Kathe Offline
Jerry Kathe  Offline
and looses 25 hp.
If 9 lbs of vacuum is costing you 25hp....I believe I would take it back to your builder and tell him to fix it.
Re: what gains did you find with dry sump? [Re: Jerry Kathe] #1708636
12/11/14 11:48 PM
12/11/14 11:48 PM
San Jose Ca.
San Jose Ca.
and looses 25 hp.
Dont' know much about a real race engine do you?
Re: what gains did you find with dry sump? [Re: boatracer572] #1708637
12/12/14 01:08 AM
12/12/14 01:08 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
and looses 25 hp.
that's
no I don't think he does
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: what gains did you find with dry sump? [Re: Jerry Kathe] #1708638
12/12/14 01:09 AM
12/12/14 01:09 AM
and looses 25 hp.
Me thinks he builds his own motors as well as for other racers on here To late, he beat me to it
Re: what gains did you find with dry sump? [Re: Cab_Burge] #1708639
12/12/14 01:27 AM
12/12/14 01:27 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Tony is the man......I was trying to be silent but.......he is a camshaft designer, fabricator, engine builder, and friend.
Re: what gains did you find with dry sump? [Re: camastomcat] #1708640
12/12/14 05:51 AM
12/12/14 05:51 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Regarding vacuum with only a dry sump pump.
Reas this thread, it is possible to have 17" in some motor combinations.
http://www.yellowbullet.com/forum/showthread.php?t=1134290&highlight=
Re: what gains did you find with dry sump? [Re: boatracer572] #1708641
12/12/14 09:11 AM
12/12/14 09:11 AM
Jerry Kathe Offline
Jerry Kathe  Offline
That was a suggestion not an insult. A few on this board clearly need to chill.
Simple as this....if you have efficient ring seal - even with the most exotic of ring packages....you will be hard pressed to gain 25hp fro the system in total. If you loose 25 on 9lb....you didnt get it done......dont bother trying to convince me otherwise.
Maybe its not me that doesn't understand "real racing engines"
Re: what gains did you find with dry sump? [Re: Jerry Kathe] #1708642
12/12/14 09:14 AM
12/12/14 09:14 AM
Jerry Kathe Offline
Jerry Kathe  Offline
BTW....sorry....didnt realize you were your own engine builder.....but if you want to find some real gains....go back and look at what im trying to tell you.
Re: what gains did you find with dry sump? [Re: Jerry Kathe] #1708643
12/12/14 10:33 AM
12/12/14 10:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just for your info... vac is measured in inches of
HG not pounds
Re: what gains did you find with dry sump? [Re: MR_P_BODY] #1708644
12/12/14 11:28 AM
12/12/14 11:28 AM
Jerry Kathe Offline
Jerry Kathe  Offline
O
engines"
HG not pounds
Good gawd.....you know what I meant.....you boys split more hair than a barber...
Re: what gains did you find with dry sump? [Re: Jerry Kathe] #1708645
12/12/14 11:33 AM
12/12/14 11:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
O
engines"
HG not pounds
I'm just trying to tell you what is proper....most
people would just says thanks for the info... I guess
you dont
Re: what gains did you find with dry sump? [Re: MR_P_BODY] #1708646
12/12/14 12:20 PM
12/12/14 12:20 PM
Jerry Kathe Offline
Jerry Kathe  Offline
HG not pounds
you dont
If "proper" is so important. ...why didnt you use the modern scale for gauging vacuum.....kPa.....and your welcome.
Re: what gains did you find with dry sump? [Re: Jerry Kathe] #1708647
12/12/14 12:28 PM
12/12/14 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
HG not pounds
you dont
I guess your gonna ALWAYS BE RIGHT... no matter what
anyone says... keep calling it POUNDS of vac.. if
your happy then thats all that counts.... by the
way.. my gauges read both... but in the USA we tend
to use inch of HG... maybe you call it pounds of KPA..
I tried to help you out with just a little info and
thats all.... do what you want
Re: what gains did you find with dry sump? [Re: Jerry Kathe] #1708648
12/12/14 12:31 PM
12/12/14 12:31 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
HG not pounds
you dont
Not since docbutthead was here have I felt the need to use this...
Re: what gains did you find with dry sump? [Re: Challenger 1] #1708649
12/12/14 12:36 PM
12/12/14 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok
Re: what gains did you find with dry sump? [Re: RT540] #1708650
12/12/14 06:42 PM
12/12/14 06:42 PM
AndyF Offline
AndyF  Offline
Yeah, a good dry sump pump these days should be able to pull up to 20" or more depending on how fast you want to spin it. My new Peterson pump will pull more than 15" when I'm running at 50% of crank speed.
As for the other debate, if the rings package is designed to work with a crankcase vacuum then running the engine without a vacuum will drop the HP a bunch. That is just the way the engine is designed and it doesn't mean that the engine is built wrong. Super narrow rings need the help from crankcase vacuum to seal. That is why a Pro class engine will lose 50 hp if you put a breather on the valve cover. Those engines are designed to be run sealed up with a pan vacuum.
Re: what gains did you find with dry sump? [Re: AndyF] #1708651
12/12/14 07:04 PM
12/12/14 07:04 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
May have already been said, but a big block mopar has the crank buried in between the block skirts. Makes it hard to get the oil off the crank so not so much to gain dry.
sure 20+ inches of vac will do more than anything else for power, but you can get away with 15 wet so I don't see it being worth it unless you need a lower crank center.
Sure vac helps the rings seal a bunch, but I think most of the power is from not having to fight the air like a plane propeller inside the crank case. Think how much power it takes to run a fan 500 rpm. Now imagine a crank coated, and slinging oil at 9,000 rpm. 21 inches is near outer space and near zero air drag.
Page 2 of 3 1 2 3
