Exhaust manifolds #1708324
12/08/14 07:57 PM
12/08/14 07:57 PM
ar
reborn73 Offline OP
reborn73  Offline OP
ar
Just bought a '73 E body 340auto. Has some cheap headers. I wanna go back with OEM manifolds. Any suggestions???
Where to get them? $$$?
The only salvage yard around told me that the 360 ones are the same.
Thanks,
Re: Exhaust manifolds [Re: reborn73] #1708325
12/08/14 08:09 PM
12/08/14 08:09 PM
Northeastern PA
Fanning Offline
Fanning  Offline
Northeastern PA
I would try E body parts for sale on this board:
https://board.moparts.org/ubbthreads/show...0&fpart=all
Also other members may chime in with the correct casting numbers (sorry I don't Know them). Good luck in your search.
Re: Exhaust manifolds [Re: reborn73] #1708326
12/08/14 09:57 PM
12/08/14 09:57 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Early model hi-po units fetch a premium in the want ads here and on ebay..
Later model, like what would have come on your car, can be found pretty cheap on ebay.
Any late 340 and 360 will work fine up until the air injected logs. Just make sure to get a center dump for the passenger side, and a rear dump for the driver.
If you want to go on a treasure hunt, hit up the junkyards for the large exit early magnum engine manifolds.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
