Page 4 of 4 1 2 3 4
Re: Victor small block Mopar head updates. [Re: WHITEDART] #1707625
12/12/14 11:23 PM
12/12/14 11:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Boy........... Just dreaming... ..... If this head indeed is only just as good as Brett noted.... Still good steam.
I just let slip by my grasp a virgin 4 bolt X block. Was offered it for 1300 bucks.
Kinda got tired of waiting on this head.
Anyhow good block, that head, 4150 carb, a 4.125 crank kit from Rod, and a streetable roller a guy could take a typical A body and have a 9 sec pump gas grocery getter, without working up too much of a sweat.
For an old schooler, a good( hopefully) nice casting is welcome news.
Sure wouldn't be cheap, but at least the heads hopefully won't be water fountains.
Cool old school is mighty appealing to old goats like me.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Victor small block Mopar head updates. [Re: moparclown] #1707626
12/12/14 11:25 PM
12/12/14 11:25 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
So did the heads make it to the PRI show?
Saw a picture on fb that Mancini posted of the SB Victors at the Edelbrock display.
Re: Victor small block Mopar head updates. [Re: moparguy7074] #1707627
12/13/14 12:21 AM
12/13/14 12:21 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
There was one victor head at the SEMA show 2 yrs ago...probably the same head.
Tony
70 AARCuda Vitamin C
Re: Victor small block Mopar head updates. [Re: moparguy7074] #1707628
12/13/14 12:25 AM
12/13/14 12:25 AM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
Now thats a good sign,might have to put this back into service
Re: Victor small block Mopar head updates. [Re: pittsburghracer] #1707629
12/13/14 08:50 PM
12/13/14 08:50 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
The Pro Port castings are supposed to be available in February. The CNC'd head on display had an intake port in it that wasn't in too good of shape, best bet would be to wait for Brett to do a program for them.
Apologies for the less than quality pic.
Re: Victor small block Mopar head updates. [Re: LSP] #1707630
12/13/14 08:55 PM
12/13/14 08:55 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Hopefully you don't need a program for an already CNC'd head. I hope its maybe just a slight hand touch-up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Victor small block Mopar head updates. [Re: pittsburghracer] #1707631
12/13/14 09:00 PM
12/13/14 09:00 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
A 2.15" intake valve on a small block Mopar? Makes me wonder what the minimum bore sized will be. I hope it doesn't make the block issues worse
Keith
Re: Victor small block Mopar head updates. [Re: B3422W5] #1707632
12/13/14 09:02 PM
12/13/14 09:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I know where you can get a virgin X block with all machine work done, bushed lifter bore and all
Re: Victor small block Mopar head updates. [Re: Quicktree] #1707633
12/14/14 12:11 AM
12/14/14 12:11 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
Re: Victor small block Mopar head updates. [Re: 70AARcuda] #1707634
12/14/14 02:52 AM
12/14/14 02:52 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
There was one victor head at the SEMA show 2 yrs ago...probably the same head. [/quote
No they had two heads there. The guy that designed them said they are being machined right now. Said they had thirty set in the shop geting done.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Victor small block Mopar head updates. [Re: 1967dartgt] #1707635
12/14/14 03:24 AM
12/14/14 03:24 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://board.moparts.org/ubbthreads/show...part=2&vc=1
there is the ONE head they had on display a couple of years ago at the sema show...
Tony
Re: Victor small block Mopar head updates. [Re: Quicktree] #1707636
12/14/14 09:49 AM
12/14/14 09:49 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Re: Victor small block Mopar head updates. [Re: HotRodDave] #1707637
12/24/14 01:18 PM
12/24/14 01:18 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
The flow numbers are from our bench based on the prototype head we were given and also some flow numbers given to us by Edelbrock. We have been working with them on this head for several years.
Re: Victor small block Mopar head updates. [Re: Dunnuck Racing] #1707638
12/24/14 02:18 PM
12/24/14 02:18 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Keith
Re: Victor small block Mopar head updates. [Re: Quicktree] #1707639
12/24/14 07:57 PM
12/24/14 07:57 PM
IL
knyech1 Offline
knyech1  Offline
IL
I want!!
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Page 4 of 4 1 2 3 4
