Re: Victor small block Mopar head updates.
[Re: WHITEDART]
#1707625
12/12/14 11:23 PM
12/12/14 11:23 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Boy........... Just dreaming... ..... If this head indeed is only just as good as Brett noted.... Still good steam. I just let slip by my grasp a virgin 4 bolt X block. Was offered it for 1300 bucks. Kinda got tired of waiting on this head. Anyhow good block, that head, 4150 carb, a 4.125 crank kit from Rod, and a streetable roller a guy could take a typical A body and have a 9 sec pump gas grocery getter, without working up too much of a sweat. For an old schooler, a good( hopefully) nice casting is welcome news. Sure wouldn't be cheap, but at least the heads hopefully won't be water fountains. Cool old school is mighty appealing to old goats like me.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: moparclown]
#1707626
12/12/14 11:25 PM
12/12/14 11:25 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
So did the heads make it to the PRI show?
Saw a picture on fb that Mancini posted of the SB Victors at the Edelbrock display.
[Re: moparguy7074]
#1707628
12/13/14 12:25 AM
12/13/14 12:25 AM
Posts: 1,922 canaan ct usa
moparclown
canaan ct usa
Now thats a good sign,might have to put this back into service
[Re: B3422W5]
#1707632
12/13/14 09:02 PM
12/13/14 09:02 PM
Quicktree
I know where you can get a virgin X block with all machine work done, bushed lifter bore and all
[Re: Quicktree]
#1707633
12/14/14 12:11 AM
12/14/14 12:11 AM
Posts: 791 Bama
Randy..
Bama
[Re: Quicktree]
#1707636
12/14/14 09:49 AM
12/14/14 09:49 AM
Posts: 2,709 NJ central
Scamp408
NJ central
[Re: Dunnuck Racing]
#1707638
12/24/14 02:18 PM
12/24/14 02:18 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
A 2.15" intake valve on a small block Mopar? Makes me wonder what the minimum bore sized will be. I hope it doesn't make the block issues worse Keith
[Re: Quicktree]
#1707639
12/24/14 07:57 PM
12/24/14 07:57 PM
Posts: 486 IL
knyech1
IL
I want!!
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
