Re: Victor small block Mopar head updates.
[Re: WHITEDART]
#1707625
12/12/14 11:23 PM
12/12/14 11:23 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Boy........... Just dreaming... ..... If this head indeed is only just as good as Brett noted.... Still good steam. I just let slip by my grasp a virgin 4 bolt X block. Was offered it for 1300 bucks. Kinda got tired of waiting on this head. Anyhow good block, that head, 4150 carb, a 4.125 crank kit from Rod, and a streetable roller a guy could take a typical A body and have a 9 sec pump gas grocery getter, without working up too much of a sweat. For an old schooler, a good( hopefully) nice casting is welcome news. Sure wouldn't be cheap, but at least the heads hopefully won't be water fountains. Cool old school is mighty appealing to old goats like me.
[Re: moparclown]
#1707626
12/12/14 11:25 PM
12/12/14 11:25 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
So did the heads make it to the PRI show?
Saw a picture on fb that Mancini posted of the SB Victors at the Edelbrock display.
[Re: moparguy7074]
#1707628
12/13/14 12:25 AM
12/13/14 12:25 AM
Posts: 1,922 canaan ct usa
moparclown
canaan ct usa
Now thats a good sign,might have to put this back into service
[Re: B3422W5]
#1707632
12/13/14 09:02 PM
12/13/14 09:02 PM
Quicktree
I know where you can get a virgin X block with all machine work done, bushed lifter bore and all
[Re: Quicktree]
#1707633
12/14/14 12:11 AM
12/14/14 12:11 AM
Posts: 791 Bama
Randy..
Bama
[Re: Quicktree]
#1707636
12/14/14 09:49 AM
12/14/14 09:49 AM
Posts: 2,709 NJ central
Scamp408
NJ central
[Re: Dunnuck Racing]
#1707638
12/24/14 02:18 PM
12/24/14 02:18 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
A 2.15" intake valve on a small block Mopar? Makes me wonder what the minimum bore sized will be. I hope it doesn't make the block issues worse Keith
[Re: Quicktree]
#1707639
12/24/14 07:57 PM
12/24/14 07:57 PM
Posts: 486 IL
knyech1
IL
I want!!
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
