Page 2 of 4 1 2 3 4
Re: Victor small block Mopar head updates. [Re: b1dartsport] #1707585
12/07/14 09:40 PM
12/07/14 09:40 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
If these #s are correct these puppies are in W8-9 territory. I better wait before I bolt the Indys on the new R3 shortblock I have on the stand right now!!
Even though they are in W9 territory they are a 59° Head ,well they pull the same RPMs as a 48° block?
Re: Victor small block Mopar head updates. [Re: RAY1969CARS] #1707586
12/07/14 09:43 PM
12/07/14 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
IF you have a GOOD valve train
Re: Victor small block Mopar head updates. [Re: pittsburghracer] #1707587
12/07/14 10:02 PM
12/07/14 10:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Ritter block is available.
I know of one that has $9000 worth of machine work and it still won't run and they have given up.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Victor small block Mopar head updates. [Re: RAY1969CARS] #1707588
12/07/14 10:25 PM
12/07/14 10:25 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Just make it bigger, like 440-470 ci and you don't have to worry about the RPMs. It will make a ton of torque, more horsepower and operate in the same RPM range.
Re: Victor small block Mopar head updates. [Re: tubtar] #1707589
12/07/14 10:38 PM
12/07/14 10:38 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Lift Intake Exhaust
.050 39.3 29.7
.100 75.8 57.4
.150 116.1 84.8
.200 167.4 115.5
.250 207.6 134.5
.300 238.5 154.1
.350 267.5 170.9
.400 296.2 187.0
.450 320.9 201.7
.500 339.3 212.3
.550 348.5 221.4
.600 357.3 227.7
.650 362.4 233.6
.700 366.7 238.6
.750 371.1 243.1
.800 371.3 246.7
Copied and pasted from their site.
Very nice numbers.......definitely enough air to saw a stock block in half with the right corresponding components.
I have seen some pretty high numbers of this bench, would like to see some others flow them. Can't wait to see some on track numbers in hands of racers.
Re: Victor small block Mopar head updates. [Re: b1dartsport] #1707590
12/07/14 10:49 PM
12/07/14 10:49 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
What block are you going to bore that big. Lolol we're up the river with no paddle lolol
Re: Victor small block Mopar head updates. [Re: RAY1969CARS] #1707591
12/07/14 11:18 PM
12/07/14 11:18 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
What block are you a boy that big. Lolol we're [Edited by Moparts - Family Friendly Site - Keep it clean] lolol
40cfm short of bretts big port w8's but still a shot in the arm for sbm guys O and almost forgot ritter blocks dont work they are junk... A waste of good metal
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Victor small block Mopar head updates. [Re: WHITEDART] #1707592
12/07/14 11:30 PM
12/07/14 11:30 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Those flow almost as good as a cnc'd 6.4 head.
Mopar to the bone!!!
Re: Victor small block Mopar head updates. [Re: WHITEDART] #1707593
12/07/14 11:35 PM
12/07/14 11:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....says whom I believe is the owner of the only Ritter block small block that survived a dyno session.
Re: Victor small block Mopar head updates. [Re: RAY1969CARS] #1707594
12/07/14 11:39 PM
12/07/14 11:39 PM
b1dartsport Offline
b1dartsport  Offline
When I had my R3 sonic checked the Machinist told me it would go 4.125 easy. 4.125 X 4.250 BPE crank = 454.38 ci. A Siamese R3 will go 4.200 to 4.250. 4.250 x 4.250 = 482.33 ci. Don't tell me this would be too expensive,you are wasting your time if you use heads that flow like this with out spending some money to make them shine.
Re: Victor small block Mopar head updates. [Re: 72Swinger] #1707595
12/08/14 12:00 AM
12/08/14 12:00 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Who cares about flow #s 20yr old Indy sb heads make more power then gen3 stiff..
Re: Victor small block Mopar head updates. [Re: b1dartsport] #1707596
12/08/14 12:01 AM
12/08/14 12:01 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
How many small block guy. Are there out there that have aready jump ship went to the new hemi Small block race blocks are going to be worth their weight in gold
Re: Victor small block Mopar head updates. [Re: b1dartsport] #1707597
12/08/14 12:05 AM
12/08/14 12:05 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The exhaust numbers are pretty weak compared to the intake side. I don't know how you can justify the productionof a new head that would still be that weak on the eexhaust.
Keith
Re: Victor small block Mopar head updates. [Re: Dunnuck Racing] #1707598
12/08/14 12:26 AM
12/08/14 12:26 AM
b1dartsport Offline
b1dartsport  Offline
Keith
I am real interested to see what these heads will do once some of the porting wizards on this site get their hands on them. If they are that good who knows what effort was put into them to get the numbers we are seeing. Its nice to see something that may be close to Max effort available for 59*. I think these may be a good replacement for the Indy 245 CC square port lawn sprinklers.
Re: Victor small block Mopar head updates. [Re: fishy340] #1707599
12/08/14 12:29 AM
12/08/14 12:29 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Could you elaborate on this? Specifics on the comparison between the two?
Re: Victor small block Mopar head updates. [Re: b1dartsport] #1707600
12/08/14 12:57 AM
12/08/14 12:57 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Nice numbers for a decent build, but nowhere near a killer W8.
A W8 will support 1000+ with a cast single at 420ci.
Re: Victor small block Mopar head updates. [Re: GTS340] #1707601
12/08/14 01:53 AM
12/08/14 01:53 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Look at his own car, 3235 lbs Cuda with indy 245 heads went 5.62 to the eight which is faster then the fastest nitrous hemi in country. He was shooting 150 the hemi is shooting 400 and only went 5.71. Proof is in a time slip not a dyno.
Re: Victor small block Mopar head updates. [Re: 1967dartgt] #1707602
12/08/14 02:05 AM
12/08/14 02:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Look at his own car, 3235 lbs Cuda with indy 245 heads went 5.62 to the eight which is faster then the fastest nitrous hemi in country. He was shooting 150 the hemi is shooting 400 and only went 4.71. Proof is in a time slip not a dyno.
I was just poking at you guys, chill out. I love SB Mopes, im glad you guys are fast but WTF how is a 4.71 slower than a 5.62 mang?
Re: Victor small block Mopar head updates. [Re: 72Swinger] #1707603
12/08/14 02:16 AM
12/08/14 02:16 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Sorry fixed it, typo. When they get the rockers figured out on the hemi it will be a good race motor.
Re: Victor small block Mopar head updates. [Re: 1967dartgt] #1707604
12/08/14 02:29 AM
12/08/14 02:29 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
now T&D is making a nice rocker arm for the hemi.and harlem sharp has a new version seems to work well.I don't think it's fair that we compare a performance w series or aftermarket Indy head to a production Gen 3
Page 2 of 4 1 2 3 4
