A body 3in inboard spring kit #170514
12/19/08 10:26 AM
12/19/08 10:26 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Does anybody have specs or pic so I can make my own boxes? I heard the mopar ones are real thin.
Re: A body 3in inboard spring kit [Re: Scamp408] #170515
12/19/08 10:53 AM
12/19/08 10:53 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I've installed them on several cars with no problem. The stock frame rails are even thinner than the M/P box kit. But if you must make your own ,just measure your front spring bushing and make it 1/16 to 1/8 inch bigger, and it will be fine
Re: A body 3in inboard spring kit [Re: Scamp408] #170516
12/19/08 11:28 AM
12/19/08 11:28 AM
ohio
prochamp Offline
prochamp  Offline
ohio
when we relocated mine we took the frt hanger and welded it inside the new m/p box,made it extra strong.been in there since 1990 with no wear/problem.
Re: A body 3in inboard spring kit [Re: prochamp] #170517
12/19/08 11:53 AM
12/19/08 11:53 AM
Canada
lenweiler Offline
lenweiler  Offline
Canada
We used the kit. Very simple. The frame material is thinner. We ended up re-inforcing there..... For extra strength. Likely not necessary.
http://smg.photobucket.com/albums/v77/zackweiler/Dad/
Damn! I dropped my change.............
