fury brakes #1703908
11/27/14 04:28 PM
11/27/14 04:28 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
Will 1973 polara disc brakes swap to a 66 fury or is the scarebird route a better option?
Re: fury brakes [Re: 72d100] #1703909
11/27/14 10:17 PM
11/27/14 10:17 PM
Andrewh Online content
Andrewh  Online Content
direct bolt in.
you only need the spindles and stuff attached to it. you can reuse your old upper and lower ball joints and the a-arms.
I would probably take the proportioning valve.
the booster will interfere with column shift too, but it will bolt in.
you just won't be able to get into low.
you can use the original drum one, but it doesn't supply enough boost, plus the master won't have a big enough resevior for the discs.
you can stop, just not lock them up.
Re: fury brakes [Re: Andrewh] #1703910
11/27/14 11:07 PM
11/27/14 11:07 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
thank you hopefully i can pick this car up pretty cheap
Re: fury brakes [Re: 72d100] #1703911
11/28/14 12:20 PM
11/28/14 12:20 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
I am doing the same exact swap exact my brakes are from a 73 New Yorker. I found a master cylinder/booster on Summit for a 69 Fury that is a dual diaphragm booster that shouldnt interfere with the linkage. I think it is 150 bucks.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: fury brakes [Re: KingTuna] #1703912
11/28/14 12:32 PM
11/28/14 12:32 PM
any parts from 65-73 should work.
if you can find an early disc brake car with the dual diaphram it will work. but most of those are pretty expensive.
you will have to let us know how the 69 one works out.
Re: fury brakes [Re: Andrewh] #1703913
11/28/14 02:07 PM
11/28/14 02:07 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you have a console shift, the 73 booster will work OK as there is no shift linkage to interfere with.
I have a booster off a 69 300 in my 66 New Yorker and while I can't swear that it will work with a column shift, (mine has a console) I do believe it is the smaller diameter dual diaphragm style which "should" work with the column shift linkage.
I think you can find it on any disc brake C-body up to 71.
Kevin
Re: fury brakes [Re: Twostick] #1703914
11/28/14 04:32 PM
11/28/14 04:32 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
I'll let you know how it goes. I hope to have the car back on the road by March. Here is the link for the master cylinder: http://www.summitracing.com/parts/aaz-50-3600/overview/year/1969/make/plymouth/model/fury-ii
1966 Fury II 4 door
Re: fury brakes [Re: KingTuna] #1703915
11/28/14 04:36 PM
11/28/14 04:36 PM
ah, you will have to let us know what you actually get.
that looks like the master power brake setup.
giving you a chevy master.
but the picture might not be what you get.
Re: fury brakes [Re: Andrewh] #1703916
11/28/14 04:43 PM
11/28/14 04:43 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
Yeah, it really annoys me that nowadays they can't take the time to put the correct picture of what you are actually buying. I did call Summit and make sure it would actually be a rebuilt master for that model year car.
1966 Fury II 4 door
Re: fury brakes [Re: KingTuna] #1703917
11/29/14 03:07 AM
11/29/14 03:07 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
The dual-diaphragm was used until 70, 71 started the large single diaphragm.
To expand on soemthign already mentioned:
Do *not* use a drumbrake booster for discs. It will work OK for normal use, but under heavy braking it will not provide enough boost for discs, so your braking will be reduced from what it should be.
Hasn't been mentioned yet, but C-bodies use different pedal setups between MB and PB, so if going to PB make sure to use a PB pedal.
I have manual discs on my 68 Fury and the braking is very good and has similar feel to the manual drums (meaning longer pedal travel and good modulation).
Re: fury brakes [Re: Fury Fan] #1703918
11/30/14 10:15 PM
11/30/14 10:15 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
Well I'm now the proud owner of a 1973 polara
