Page 1 of 9 1 2 3 4 5 6 7 8 9
Radial Duster Build #1703450
11/26/14 12:58 PM
11/26/14 12:58 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
small block turbo build WILL be street driven to the local cruises, meets,and to the track occaisonally
R block
winberg billet 3.25 crank
comes out to 340 ci
baton blue plug w5 heads
custom bullet solid roller
EFI
Glide
a2w intercooler
"stock" suspension
how is was when i got it
got it cleaned up a little bit
tear down begins
got it blasted in, out, underneath.. no more undercoating, or sound deadener, all clean and ready for work
wheel tubs and trunk floor in.. tubbed it to the stock frame rail
had to mod the intake for EFI
let the roll cage work begin.. full cromoly 25.5
will have 100% of the interior including the back seat
Re: Radial Duster Build [Re: rgreule] #1703451
11/26/14 01:03 PM
11/26/14 01:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Damn nice work there sir..................man, I envy you guys that can bend and weld.
Re: Radial Duster Build [Re: Thumperdart] #1703452
11/26/14 01:07 PM
11/26/14 01:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
looks great, should haul ash. One thing... will it pass tech with the bars bent like that? I thought they had to be straight
Coming soon!!!!
Re: Radial Duster Build [Re: rgreule] #1703453
11/26/14 01:08 PM
11/26/14 01:08 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Great build! Very similar to mine, your a little farther along than me though.
What did ya use to get the undercoat crap off the inside of the quarters? That stuff is a pain. Also how close is your driveshaft to the top of the tunnel at that ride hight?
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Radial Duster Build [Re: rgreule] #1703454
11/26/14 01:09 PM
11/26/14 01:09 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
the rear suspension, 9 inch, SRD assassin bars, sliders
the intercooler and brake pedal setup.
HDK front suspension
make the fonts really tuck in nicely
the turbo setup stuff.. will be doing new headers, and redoing the firewall in the next few weeks...
dash was fitted for the racepak cluster
thats all for now.. will be nice when i can take it apart and get it all painted and the suspension all powdercoated all nice..
thanks for looking
Re: Radial Duster Build [Re: Quickrunner] #1703455
11/26/14 01:11 PM
11/26/14 01:11 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: Radial Duster Build [Re: rgreule] #1703456
11/26/14 01:12 PM
11/26/14 01:12 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
the tunnel will need raised in the back section of it, i will mod the rear seat to make it fit.. all the undercoating and sound deadener on the inside of the quarters, doors and so on was all blasted off when i had the car blasted.. saved me a TON of work
Re: Radial Duster Build [Re: rgreule] #1703457
11/26/14 01:15 PM
11/26/14 01:15 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
it sits pretty low, thats a 325 stuffed in there
Re: Radial Duster Build [Re: rgreule] #1703458
11/26/14 01:55 PM
11/26/14 01:55 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
WOW!! Thats a serious ride...Keep the pics coming!!
2 kids and a dog
Re: Radial Duster Build [Re: TonyS451] #1703459
11/26/14 03:10 PM
11/26/14 03:10 PM
Chesterfield Twp. Mi.
John Burdine Offline
who's brake peddle/master cylinder set-up is that?
Re: Radial Duster Build [Re: John Burdine] #1703460
11/26/14 03:27 PM
11/26/14 03:27 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Very nice!
Jeff
69 GTX 68 Road Runner
Re: Radial Duster Build [Re: John Burdine] #1703461
11/26/14 03:27 PM
11/26/14 03:27 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Wilwood
Re: Radial Duster Build [Re: bigdad] #1703462
11/26/14 07:42 PM
11/26/14 07:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I like the car.The 8 3/4 in Dizusters mild turbo build didn't last a season. pinion shaft broke , cleared all the ring gear teeth at 20 psi
Doug
Re: Radial Duster Build [Re: dvw] #1703463
11/26/14 08:32 PM
11/26/14 08:32 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep! Good news though, Dr.Diff is having a special on Dana 60's right now, now shipping charges!
Re: Radial Duster Build [Re: rgreule] #1703464
11/26/14 10:35 PM
11/26/14 10:35 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Interesting build, I like the car
"Just a Bracket car dressed up like a streetcar"
Re: Radial Duster Build [Re: Just-a-dart] #1703465
11/26/14 11:10 PM
11/26/14 11:10 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Nice, what ET are you hoping for?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Radial Duster Build [Re: Just-a-dart] #1703466
11/26/14 11:33 PM
11/26/14 11:33 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Guys it's a nine inch it will be fine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Radial Duster Build [Re: 1967dartgt] #1703467
11/27/14 12:44 AM
11/27/14 12:44 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I missed the dimples in the sides of the housing.
Doug
Re: Radial Duster Build [Re: Stroker Scamp] #1703468
11/29/14 03:05 PM
11/29/14 03:05 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
im hoping to get this thing to touch the 7s.. all the math says it will but we will see in real life..
Re: Radial Duster Build [Re: rgreule] #1703469
12/04/14 01:28 AM
12/04/14 01:28 AM
IL
knyech1 Offline
knyech1  Offline
IL
I'm pulling my Demon apart now. Was hoping to go with a smaller tire, new moly cage, and put a back seat in it!!
What cage is that, and what are the size of your tubs? I'm running a 32x14.5W tire and would like to reduce the tub size to fit a rear seat. Awesome build!
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
