Radial Duster Build
#1703450
11/26/14 12:58 PM
11/26/14 12:58 PM
Posts: 155 Post falls, Idaho
rgreule
Post falls, Idaho
small block turbo build WILL be street driven to the local cruises, meets,and to the track occaisonally R block winberg billet 3.25 crank comes out to 340 ci baton blue plug w5 heads custom bullet solid roller EFI Glide a2w intercooler "stock" suspension how is was when i got it got it cleaned up a little bit tear down begins got it blasted in, out, underneath.. no more undercoating, or sound deadener, all clean and ready for work wheel tubs and trunk floor in.. tubbed it to the stock frame rail had to mod the intake for EFI let the roll cage work begin.. full cromoly 25.5 will have 100% of the interior including the back seat
Re: Radial Duster Build
[Re: rgreule]
#1703453
11/26/14 01:08 PM
11/26/14 01:08 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Great build! Very similar to mine, your a little farther along than me though. What did ya use to get the undercoat crap off the inside of the quarters? That stuff is a pain. Also how close is your driveshaft to the top of the tunnel at that ride hight?
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: rgreule]
#1703458
11/26/14 01:55 PM
11/26/14 01:55 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
WOW!! Thats a serious ride...Keep the pics coming!!
2 kids and a dog
[Re: Just-a-dart]
#1703466
11/26/14 11:33 PM
11/26/14 11:33 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Guys it's a nine inch it will be fine.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1703467
11/27/14 12:44 AM
11/27/14 12:44 AM
Posts: 9,841 MI, usa
dvw
MI, usa
I missed the dimples in the sides of the housing. Doug
[Re: Stroker Scamp]
#1703468
11/29/14 03:05 PM
11/29/14 03:05 PM
rgreule
Post falls, Idaho
Nice, what ET are you hoping for?
im hoping to get this thing to touch the 7s.. all the math says it will but we will see in real life..
[Re: rgreule]
#1703469
12/04/14 01:28 AM
12/04/14 01:28 AM
Posts: 486 IL
knyech1
IL
I'm pulling my Demon apart now. Was hoping to go with a smaller tire, new moly cage, and put a back seat in it!! What cage is that, and what are the size of your tubs? I'm running a 32x14.5W tire and would like to reduce the tub size to fit a rear seat. Awesome build!
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
