Re: what cam are you running in your RB stroker
[Re: 451Mopar]
#1703447
11/27/14 04:12 AM
11/27/14 04:12 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
This is my cam card for my 512 b motor stroker. I set the initial at 19 degrees and backed the mechanical to 36ish after reading a bunch of threads on here. Also dialed the vacuum advance back a bunch of turns to eliminate pinging. It's a bear off the line, smoke and sideways etc.
Custom spec from Mike @ Muscle Motors.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: gregsrt]
#1703448
11/27/14 10:46 AM
11/27/14 10:46 AM
Posts: 3,152 Central NC
gch
Central NC
496 with 9.2-1(no quench),ported iron heads,ported ch4b intake,Holley 750 hp,TTi 1 7/8 headers,3" to x pipe/2.5 back,11" converter,3.55 gears,16-18* initial 35* total in a 4400+lb c body and has run a best of 12.54 @ 107 with drag radials.
HUG HTL3742BS
Camshaft Technical Details Intake Valve Lift 1.5 Exhaust Valve Lift 1.5 .534" .543"
Intake Valve Lift 1.6 Exhaust Valve Lift 1.6 .569" .579"
Intake Duration at .050" Exhaust Duration at .050" 237° 242°
Lobe Separation Angle 109
Intake Opening at .050" Exhaust Opening at .050" 12.5° BTC 53° BBC
Intake Closing at .050" Exhaust Closing at .050" 44.5° ABC 9° ATC
[Re: stateroadhog]
#1703449
11/27/14 07:49 PM
11/27/14 07:49 PM
Posts: 2,138 tucson az
frank
tucson az
In my 440/496 I am running a comp hyd roller. It was custom ground for my engine from part #23-000-9. gross lift at intake .589/exhaust .595 duration at .050 .242/.248
Ported Eddy heads, 9.7 comp, Holley SD, 4 speed, 3.54 rear, 1 7/8 headers with 3 inch exhaust, MSD pro billet distributer, Proform 850DP, total timing 34 degrees Car runs extremely well and will melt tires at will
