Page 2 of 3 1 2 3
Re: Finally a BB automatic overdrive tranny! [Re: GLR] #1702063
11/24/14 12:51 AM
11/24/14 12:51 AM
BDW Online content
BDW  Online Content
No cutting for E or B bodies, just finished my install, amazing difference.
Good read here, get the LU
http://www.cuda-challenger.com/cc/index.php?topic=84774.msg847873#msg847873
Re: Finally a BB automatic overdrive tranny! [Re: BDW] #1702064
11/24/14 01:09 AM
11/24/14 01:09 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is a 518 really 2' longer than a 727? Gotta be a typo.
Lockup Torque Converter for Extra RPM decrease (also aides in fluid cooling)
No Modifications to Linkage
Reuses Factory Case Bosses
No Engine Adapter
No Starter Relocation
No Special Computer
No Crank Shaft Spacers
No Special Flywheel
Only 2' longer in length
Keeps Transmission as far forward as possible
Kevin
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702065
11/24/14 02:54 AM
11/24/14 02:54 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Frankenduster,
And yea, 10 might be a little hopeful on an increase from a lock up. I wonder what improvement you would have seen if you stayed with the 3.23s?
That takes the discussion in another direction. I see that some engines may not get better mileage simply because they are revving less. This can be the case with aggressive camshafts where the engine is less efficient at lower RPMs. A stock engine with mild camshaft timing ? Sure.
If I decide to go with an overdrive in the future, I may choose to build a 518. My car is a keeper so any changes I make would not be skewed by thoughts of resale value.
Re: Finally a BB automatic overdrive tranny! [Re: Kern Dog] #1702066
11/24/14 02:18 PM
11/24/14 02:18 PM
dogdays Offline
dogdays  Offline
What puzzles me is they say you have to supply a core, but not what kind of core. Lots of typos in that ad, but not all gearheads can spell.....
Is the 0.69:1 overdrive ratio the stock 518 ratio?
When I first got my '64Dog on the road it had 3.91 gears. With 32" tires it got about 14mpg at freeway speeds. The motor was the stock Poly 318. Then I swapped rears for a later (one piece axles) with 3.23s. Mileage didn't change a bit. It made a lot less noise running at 80, so I kept the 3.23s. But there was no mileage gain at all.
R.
Re: Finally a BB automatic overdrive tranny! [Re: BDW] #1702067
11/24/14 02:30 PM
11/24/14 02:30 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
In 71-74 b-bodies, early ones the crossmember is located a few inches forward and it's makes a nite and day difference... the center of the torsion bar crossmember needs cut out basically to the floor pan.
When I went to do the swap, I missed that part, thinking it'd be easy like going in an e-body from readings links on cc.com
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Finally a BB automatic overdrive tranny! [Re: Silver70] #1702068
11/26/14 01:38 AM
11/26/14 01:38 AM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
This is good information, my thoughts are for my 71 BB Charger 500. I'll read the CC thread but if I understand ya'll correctly it will work without cutting.
The cores they request are actually 2 cores, a 518 and a BB7 27, they graft the 727 bell onto the 518. Everything else is 518, some wiring required for the electronics.
Careful, your character's showing!
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702069
11/26/14 04:12 AM
11/26/14 04:12 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
A Moparts member who also is a member at Cuda Challenger.com states that when using the JW Ultrabell, you are limited to a 10" converter since the Ultrabell is so much thicker.
Re: Finally a BB automatic overdrive tranny! [Re: Kern Dog] #1702070
11/26/14 12:19 PM
11/26/14 12:19 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I talked to PTC about converters for this swap. They indicated that there were fewer converter possibilities with the lock up. May not matter to your particular application, but it might be a good idea to check BEFORE pulling the trigger on a lock up tranny if you were going that way.
Master, again and still
Re: Finally a BB automatic overdrive tranny! [Re: DaveRS23] #1702071
11/26/14 01:45 PM
11/26/14 01:45 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I'd look into the 200r4 swap. Smaller and more parts/converters. Same basic deal. Cut off the stock bellhousing and bolt on an aftermarket. If I ever go auto again for the street it's probably where I'd start.
Re: Finally a BB automatic overdrive tranny! [Re: 80fbody] #1702072
11/26/14 05:25 PM
11/26/14 05:25 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Another advantage of the 200R4 is the gear ratio spread is better.
2.74 first gear, 1.76 second, 1.0 3rd and .67 OD. Closer gear ratios provide less RPM drop during shifts. The taller OD is a slight benefit too. This being a smaller trans, fitment and lighter internal components for faster acceleration are helpful.
ONE drawback: The trans pan on the 200 is looooooog, putting the trans mount back much further. This poses a problem for the trans crossmember. You could fab a custom crossmember and tie it to your subframe connectors if they are fully boxed and welded.
Re: Finally a BB automatic overdrive tranny! [Re: Kern Dog] #1702073
11/26/14 11:10 PM
11/26/14 11:10 PM
mopar346 Offline OP
mopar346  Offline OP
I like the idea of keeping it all Chrysler but the 200 would be cheaper to build that's for sure, maybe not depending on the power it will hold. I have considered swapping it to a 833 O/D but not really wanting a standard in this one.
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702074
11/26/14 11:50 PM
11/26/14 11:50 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
on that 200r--- a tranny guy told me you had to throw away all the internals and buy really expensive race parts to make it work---maybe $2000 worth of stuff----sounds like a deal to me----i always thought the 700r was a good hot rod tranny until i found it even needs some serious upgrades-------now my idea is of using a BB 727 4x4 tranny with some type of bolt on overdrive---you know where the transfer case bolts on---seems like some one could engineer that fairly easy----you could turn your 727 into a 6 speed auto-----dont know about a lock up converter though.....
Re: Finally a BB automatic overdrive tranny! [Re: savoy64] #1702075
11/27/14 02:38 AM
11/27/14 02:38 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
That whole " three speed into a six speed" schmere never appealed to me. If I had paddle shifters, sure. Otherwise the clumsy action of a dimmer switch for OD was impossible to do with the intentions of going faster than I could in direct drive.
If you have a real RPM limited engine operating at slow road speeds, the gear splitting might have merit. In an 11 second street car, you'd need more than a toggle or dimmer switch to make it worthwhile.
Re: Finally a BB automatic overdrive tranny! [Re: Kern Dog] #1702076
11/27/14 11:13 AM
11/27/14 11:13 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Guys with modded 6 cylinder turbo Buicks have problems getting the 200 to live so the torque of a BB Mopar is only going to make it worse! Once a friend made enough power in his T-type to run 10.80, he couldn't get the trans. to stay together.
Re: Finally a BB automatic overdrive tranny! [Re: GY3] #1702077
11/28/14 01:16 AM
11/28/14 01:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Guys have been saying that for years about the 518's too. How many of us are running 10 second street cars?
Re: Finally a BB automatic overdrive tranny! [Re: DaytonaTurbo] #1702078
11/28/14 08:14 AM
11/28/14 08:14 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Which I never understood considering its just a 727 with an overdrive slapped on. One which will take the torque of a Cummings diesel.
"I think its got a hemi"
Re: Finally a BB automatic overdrive tranny! [Re: gdonovan] #1702079
11/28/14 04:44 PM
11/28/14 04:44 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
The 518/618 units get run behind heavily modified truck that weigh upwards of 8k lbs putting out over 600hp and 1500ftlbs tq. The trans does need to be upgraded of course to take it. There are specialty converters running up to 4 disc lock up clutches in them to put up with this abuse. Of course they are expensive too. Another way to go would be to get a donor trans from a 93 back diesel or early production v8 from like 89. They did not run a lock up converter.
Carl Kessel
Re: Finally a BB automatic overdrive tranny! [Re: gdonovan] #1702080
11/28/14 07:55 PM
11/28/14 07:55 PM
Manitoba, Canada
Manitoba, Canada
And anyone who's owned one knows the ones even on stock unmodified Cummins are not known for their longevity. Not saying the 518s are bad, but they're not the holy grail either.
Re: Finally a BB automatic overdrive tranny! [Re: DaytonaTurbo] #1702081
11/28/14 10:51 PM
11/28/14 10:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I don't know of a more durable tranny than a well built 727 for most of what we all do. So, as far as the first 3 gears, a 518 would be as tough as any comparably built 727.
Now I don't know the limits of a lock-up converter or the OD section, but do those really need to hold all of our power in normal driving?
I plan to use a non lock-up 518 in the Cuda next year. The main body will be built just like the 727 in there now which has proven to be nearly indestructible. The OD will be beefed up, but I do not plan to ask it to hold all of power the engine is capable of making.
Re: Finally a BB automatic overdrive tranny! [Re: gdonovan] #1702082
11/28/14 10:52 PM
11/28/14 10:52 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You know better than that!
I ran a LOT of miles and did far more donuts, figure eights, and hang time in my 92 D250 Cummins than anybody ever expected and the transmission held up great for over 270,000 miles.
I finally had to take it out due to fluid bypassing in the OD section. None of the working parts were hurt. A few seals had let go.
- Stu Harmon
Page 2 of 3 1 2 3
