Re: 426/472 Dick Landy Hemi Rocker Assemblies
[Re: old_racer]
#1701317
11/20/14 11:35 PM
11/20/14 11:35 PM
Posts: 7,647 Minnesota
Hemi_Joel
Minnesota
They don't oil the rollers too well when the engine is cold. The oil hole for the roller end is on the shaft area of the rocker. I had problems burning up rollers until I did the following upon Mike Landy's advice: Cut a groove in the #4 cam journal to provide full time oil to the rocker gear; use 10w40 or 5w30 oil so it thins out faster. Plus I did my own modification to the rockers by using a die grinder to cut a banana shape in the bushing so the oil hole is getting oil through most of the rockers arc. That solved the problem. Below is a pic of my engine running with the valve cover off before the modifications. This is after 5 minutes of warming up the engine, and the oil is warming up and starting to squirt. When it is cold, it just droobles out and does not squirt. You can see the squirt of oil, not really aimed at the roller. Landy told me that it needs to bounce off the valve cover and back onto the roller.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1701319
11/21/14 02:32 AM
11/21/14 02:32 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I see you have collars rather than springs too.....Why? Are collars better than springs? I've never seen these collars for sale, where to get them?
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Suregrip391]
#1701320
11/21/14 10:16 AM
11/21/14 10:16 AM
Posts: 13,643 Marion, South Carolina [><]
an8sec70cuda
I use the DLI rollers rockers on my 572 hemi. Built it in 2006 and never had a problem w/ anything. Using the blue MP aluminum stands...no reason you can't run the stock stuff. Has a BUNCH of street miles and 1/4 passes on it.
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
