Re: Small block Cam Dilemma
[Re: BPE]
#1700850
11/19/14 04:57 PM
11/19/14 04:57 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Depends on the rest of the combo, is it going to be borderline ready to split the block already? If it is going to make too much power for a stock block then no, however if it is an aftermarket block then probably yes. It just kind of depends on the rest of the set up if it is worth it or not.
On another subject... Have you been able to keep 4.25 360 main cranks in stock lately? I want one but I got to sell my 4 inch stuff, don't want to sell the 4 inch stuff if I can not get the 4.25.
[Re: HotRodDave]
#1700851
11/19/14 05:00 PM
11/19/14 05:00 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
If you are trying to sell the build keep it as cheap as possible because we all know Mopar people are cheap.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1700852
11/19/14 07:17 PM
11/19/14 07:17 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Truth
[Re: Monte_Smith]
#1700856
11/19/14 08:40 PM
11/19/14 08:40 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Roller if you use good lifters, Crower, Morrell or equivalent.
Comps will go in the trash.
[Re: Leon441]
#1700857
11/19/14 08:59 PM
11/19/14 08:59 PM
Quicktree
[Re: Dunnuck Racing]
#1700862
11/21/14 01:11 AM
11/21/14 01:11 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Rod, Bring the roller set up over and test it in my small block and see what it gains you. My guess is very little for a lot of $$$$ Its amazing how so many people fear flat tappet camshafts.
Keith
I'd like to see that, say a mild cam in the 580 to 600 lift range and maybe the FT gets 1.6 rockers.
#1700863
11/21/14 02:27 AM
11/21/14 02:27 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Keith
