1965 Coronet/Belvedere real weights #1700539
11/18/14 08:49 PM
11/18/14 08:49 PM
Sydney,Australia
tex013 Online content OP
tex013  Online Content OP
Sydney,Australia
What are the real weights for either of these in a 2 door post or hardtop with a big block / auto ?
I know what the shipping weights are but they seem somewhat optimistic .
thanks
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700540
11/18/14 11:03 PM
11/18/14 11:03 PM
Austin, Texas
65Sat440 Offline
65Sat440  Offline
Austin, Texas
My 1965 Satellite factory weight was listed as 3,250. It actually weighs 3,470 lbs. The difference may be the extra weight of the 440 over the original poly 318, plus larger wheels/tires, added sway bars, etc.
Re: 1965 Coronet/Belvedere real weights [Re: 65Sat440] #1700541
11/19/14 12:05 AM
11/19/14 12:05 AM
Sydney,Australia
Sydney,Australia
thanks,
that puts it around 100lbs less than my 68 Satellite with aluminium headed 440 and fibreglass hood
Tex
New best MPH 130.32
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700542
11/19/14 12:52 AM
11/19/14 12:52 AM
AndyF Offline
AndyF  Offline
Last time I did a four corner weight check my '65 Coronet was right at 3500 lbs and was split 50/50 front to back.
It has a big block with aluminum heads, intake, water pump, etc. up front and a Dana 60 out back. So I guess that is why the distribution is even.
Re: 1965 Coronet/Belvedere real weights [Re: AndyF] #1700543
11/19/14 01:47 AM
11/19/14 01:47 AM
Sydney,Australia
Sydney,Australia
AndyF,
do you run any fibreglass panels ?
I was hoping to go lighter than my Satellite then fit a lightweight hood and bumper
Oh as an aside - if I use your replacement rear spring hangers for a Plymouth will I be able to use the 22" later springs ?
Tex
New best MPH 130.32
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700544
11/19/14 09:28 AM
11/19/14 09:28 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I want to see the 4 corner weights posted for fullmetaljacket's 65.
...FAFO...
Re: 1965 Coronet/Belvedere real weights [Re: skicker] #1700545
11/19/14 03:16 PM
11/19/14 03:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Years ago my 64 Savoy with max wedge, auto, dana, gutted interior and one van seat no bars, weighed at Budds Creek raceway, the car was 3045 lbs all steel. How accurate, don't know, but it was for the class cars at that time.
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700546
11/20/14 02:49 AM
11/20/14 02:49 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I weighed mine two years ago at a Goodguys show courtesy of Ride Tech. 3941 without my slim 280lb butt in it. Car has iron head 440, 727, 8 3/4 and had like 1/2 tank of fuel in it. It was heavier than I thought. The new Indy low deck wedge I got for it weighs 450lbs with oil in it but no accessories on it. That will help plus I lost some ballast too.
Carl Kessel
Re: 1965 Coronet/Belvedere real weights [Re: CKessel] #1700547
11/20/14 05:31 PM
11/20/14 05:31 PM
fullmetaljacket Offline
That's quite a bit heavy for an early B.
Mostly they would not top out over 3800 and change with a Big block. The A864 and A990's were 3100 and change as factory lightweights so a stock one with even a Hemi would probably be at 37-38 and change.
My post was about in the high 36 and change with a small block.
It is now 3123 with an iron Alumi-head Big block and counting till it reaches the 2900 LBS threshold.
Re: 1965 Coronet/Belvedere real weights [Re: fullmetaljacket] #1700548
11/21/14 10:45 AM
11/21/14 10:45 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Is that 3123 actual weight or advertised weight?
...FAFO...
Re: 1965 Coronet/Belvedere real weights [Re: fullmetaljacket] #1700549
11/21/14 06:52 PM
11/21/14 06:52 PM
Sydney,Australia
Sydney,Australia
thanks for the replies and info
Tex
New best MPH 130.32
Re: 1965 Coronet/Belvedere real weights [Re: skicker] #1700550
11/21/14 11:28 PM
11/21/14 11:28 PM
It's actually advertised. LOL.
Not to hi-jack this forum, another 50 Lbs is about to be shaved.
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700551
11/22/14 12:25 AM
11/22/14 12:25 AM
Cab_Burge Online work
Cab_Burge  Online Work
I had a customer who owned a 1965 Satelite with bucket seats, power steering, power brakes,radio, heater and air conditioning. He put a disc brake kit on it also, 426 street Wedge, 727, 8 3/4 vinyl top street car. It weighed over 3500 lbs wet without him in it at the old LACR, Palmdale drag strip according to there scales It was probally closet to 3700 lbs than 3500 lbs My 415 HP M.W 1963 steel front end Belevdere two door sedan had to weigh a minumum of 3320 lbs. without me in it when I first started drag racing it in NHRA stock class back in 1979 I had another bracket car, 1963 Belvedere hard top, with a Dana 70 and a mild steel Chris Alston .120 wall 12 point roll cage and steel wheel tubs that weighed over 3550 lbs with no driver on the same scales at LACR It had one small fibreglas race seat, very thin carpet, lightweight rims and light weight drag tires, no creature comforts features at all IHTHs Duster are easy to make a lot lighter than that
Re: 1965 Coronet/Belvedere real weights [Re: Cab_Burge] #1700552
11/22/14 08:31 AM
11/22/14 08:31 AM
Sydney,Australia
Sydney,Australia
Darn it Cab
Maybe i should stick with a 69/69 Plymouth
Mind you last time i weighed it was at the track scale . I weighed it on a public weighbridge when i imported the 68 7 years ago - steel bonnet all iron 440,copper radiator,cragar keystone 14" rims was about 1610kg / 3545lbs . Who the heck is accurate ?
Tex
New best MPH 130.32
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700553
11/22/14 12:12 PM
11/22/14 12:12 PM
Find a friend who may have race scales as part of their race program equipment, slip him/her a few dollars and put that pup on the scales. I have my own, but quite far away from you.
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700554
11/22/14 12:17 PM
11/22/14 12:17 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Darn it Cab
Tex
surprised it was that light. my 69 coronet r/t is 3880 dry and empty.
Re: 1965 Coronet/Belvedere real weights [Re: lewtot184] #1700555
11/22/14 02:58 PM
11/22/14 02:58 PM
Wish mine was that light from the start as well.
600 Lbs shaved and still in the 30's
Re: 1965 Coronet/Belvedere real weights [Re: fullmetaljacket] #1700556
11/22/14 05:02 PM
11/22/14 05:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
One thing is dont go by shipping weight as they are always way off. As I have said my 63 is all steel and stock with a glass hood and I added the frame connectors and a 6 point rollbar. It goes just over 3700 lbs with my 180 in it. So its about 3530 without me in it. Take out the rollbar and frame connectors its most likely about 3400 lbs and then add a few for the glass hood you got around 3450 bone stock the way Ma Mopar built it without anyone in it. Ron
Re: 1965 Coronet/Belvedere real weights [Re: 383man] #1700557
11/22/14 07:10 PM
11/22/14 07:10 PM
Sydney,Australia
Sydney,Australia
Thamks Ron , Lew and others who have chimed in
Now just find a good one .
Tex
New best MPH 130.32
Re: 1965 Coronet/Belvedere real weights [Re: tex013] #1700558
11/22/14 08:29 PM
11/22/14 08:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Tex, i love those early b's. don't care what flavor they come in. just wish i'd found one 20yrs sooner!
