Re: Lots of shock questions lately
[Re: sixpackgut]
#1700011
12/23/14 08:16 PM
12/23/14 08:16 PM
Quicktree
Monte,
If you have 90\10s or 3 ways on the front and single adj on the back, you can only afford to buy 2 shocks, which one do you replace
gonna guess fronts
[Re: Quicktree]
#1700012
12/23/14 08:33 PM
12/23/14 08:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Monte,
gonna guess fronts
A good video would tell you a lot
[Re: 1967dartgt]
#1700014
12/23/14 09:33 PM
12/23/14 09:33 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Monte,
If your car doesn't have a wheelieing problem I would go with rears. If it's pulling the wheels a lot then I would want fronts. But I don't think with your gears you have a problem in the front.
That was a very nice way to tell me Im slow. Ok, lets say i start spraying a 150 shot on it. Then fronts or rears?
Your answer better not be " you'll still be slow"
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: MR_P_BODY]
#1700015
12/23/14 09:35 PM
12/23/14 09:35 PM
Quicktree
Monte,
gonna guess fronts
don't need a video to tell me which ones I would replace first
[Re: Quicktree]
#1700016
12/23/14 09:39 PM
12/23/14 09:39 PM
MR_P_BODY
Monte,
gonna guess fronts
From what I seen on DW I would go with the rears but now he is talking spraying it... more than likely I would still go with rears... but thats JMO
[Re: Quicktree]
#1700018
12/23/14 09:48 PM
12/23/14 09:48 PM
MR_P_BODY
the rears are the better of the 2 he has. you can't control anything with a 90/10
From what I understand he has the 3 ways in front which I dont like but I have no knowledge of whats on the rear.. but as said if it isnt going way up then go with rears... again... JMO... but I like a vid so I have a better idea
[Re: MR_P_BODY]
#1700019
12/23/14 09:51 PM
12/23/14 09:51 PM
sixpackgut
Charleston
Calvert 90/10s on my fronts
[Re: sixpackgut]
#1700020
12/23/14 09:57 PM
12/23/14 09:57 PM
MR_P_BODY
Does it do big wheel stands now and are you gonna use a progressive spray control
[Re: 1967dartgt]
#1700023
12/23/14 10:13 PM
12/23/14 10:13 PM
sixpackgut
Charleston
Monte,
Don't you only have 3.54 rear gears? I would put the 3 way on the front and still get rears for nitrous use. It should go bottom nines on the hit, that would be fun to see at drag week.
Yes on the gears. So you want me to buy 4 shocks. I only gave the option of buying 2. I made the question for many guys like me that have a similar shock setup and financial status
[Re: sixpackgut]
#1700024
12/23/14 10:16 PM
12/23/14 10:16 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Oh I thought you had both fronts available. I would still go rears and if you start to have a wheeling problem you can bandaid it with front end limiters. They are easy to build on a bodies. You can use a digitset to delay the nitrous at the hit.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1700025
12/23/14 10:24 PM
12/23/14 10:24 PM
MR_P_BODY
Yeah the digisets work nicely
[Re: 1967dartgt]
#1700030
12/23/14 11:22 PM
12/23/14 11:22 PM
Quicktree
I'll go out on a limb and say Monte will say front anyway I would replace the front first if it were my car. but what do I know
Just curious why fronts? What is your thinking behind this. If it spins at the hit on greasy track what would fronts help?
because the 90/10s are going slam open bottom out and fall back down and unload the tires. maybe In am wrong, a little tire spin may not hurt him that much. he still has adjustment on the rear.
