Page 4 of 6 1 2 3 4 5 6
Re: Lots of shock questions lately [Re: sixpackgut] #1700011
12/23/14 08:16 PM
12/23/14 08:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte,
If you have 90\10s or 3 ways on the front and single adj on the back, you can only afford to buy 2 shocks, which one do you replace
gonna guess fronts
Re: Lots of shock questions lately [Re: Quicktree] #1700012
12/23/14 08:33 PM
12/23/14 08:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte,
gonna guess fronts
A good video would tell you a lot
Re: Lots of shock questions lately [Re: sixpackgut] #1700013
12/23/14 09:18 PM
12/23/14 09:18 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Monte,
If your car doesn't have a wheelieing problem I would go with rears. If it's pulling the wheels a lot then I would want fronts. But I don't think with your gears you have a problem in the front.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Lots of shock questions lately [Re: 1967dartgt] #1700014
12/23/14 09:33 PM
12/23/14 09:33 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Monte,
That was a very nice way to tell me Im slow. Ok, lets say i start spraying a 150 shot on it. Then fronts or rears?
Your answer better not be " you'll still be slow"
Re: Lots of shock questions lately [Re: MR_P_BODY] #1700015
12/23/14 09:35 PM
12/23/14 09:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte,
gonna guess fronts
don't need a video to tell me which ones I would replace first
Re: Lots of shock questions lately [Re: Quicktree] #1700016
12/23/14 09:39 PM
12/23/14 09:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte,
gonna guess fronts
From what I seen on DW I would go with the rears
but now he is talking spraying it... more than likely
I would still go with rears... but thats JMO
Re: Lots of shock questions lately [Re: MR_P_BODY] #1700017
12/23/14 09:41 PM
12/23/14 09:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the rears are the better of the 2 he has. you can't control anything with a 90/10
Re: Lots of shock questions lately [Re: Quicktree] #1700018
12/23/14 09:48 PM
12/23/14 09:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
From what I understand he has the 3 ways in front
which I dont like but I have no knowledge of whats
on the rear.. but as said if it isnt going way up
then go with rears... again... JMO... but I like
a vid so I have a better idea
Re: Lots of shock questions lately [Re: MR_P_BODY] #1700019
12/23/14 09:51 PM
12/23/14 09:51 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Calvert 90/10s on my fronts
Re: Lots of shock questions lately [Re: sixpackgut] #1700020
12/23/14 09:57 PM
12/23/14 09:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does it do big wheel stands now and are you gonna
use a progressive spray control
Re: Lots of shock questions lately [Re: sixpackgut] #1700021
12/23/14 10:06 PM
12/23/14 10:06 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Monte,
Don't you only have 3.54 rear gears? I would put the 3 way on the front and still get rears for nitrous use. It should go bottom nines on the hit, that would be fun to see at drag week.
Re: Lots of shock questions lately [Re: MR_P_BODY] #1700022
12/23/14 10:08 PM
12/23/14 10:08 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Re: Lots of shock questions lately [Re: 1967dartgt] #1700023
12/23/14 10:13 PM
12/23/14 10:13 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Monte,
Yes on the gears. So you want me to buy 4 shocks. I only gave the option of buying 2. I made the question for many guys like me that have a similar shock setup and financial status
Re: Lots of shock questions lately [Re: sixpackgut] #1700024
12/23/14 10:16 PM
12/23/14 10:16 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Oh I thought you had both fronts available. I would still go rears and if you start to have a wheeling problem you can bandaid it with front end limiters. They are easy to build on a bodies. You can use a digitset to delay the nitrous at the hit.
Re: Lots of shock questions lately [Re: 1967dartgt] #1700025
12/23/14 10:24 PM
12/23/14 10:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah the digisets work nicely
Re: Lots of shock questions lately [Re: 1967dartgt] #1700026
12/23/14 10:26 PM
12/23/14 10:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
If you notice in my picture, my front tires dont fall very much. I have huge poly bushings in there for less front end travel. Maybe that is why it doesnt lift the tires higher then it does. I do know that my car makes the trip down the track almost every time. I am of the same opinion as quicktree I just wanted to hear what Monte or Mike had to say, Not that i dont value everyones opinion
Re: Lots of shock questions lately [Re: sixpackgut] #1700027
12/23/14 11:01 PM
12/23/14 11:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I'll go out on a limb and say Monte will say front anyway I would replace the front first if it were my car. but what do I know
Re: Lots of shock questions lately [Re: sixpackgut] #1700028
12/23/14 11:06 PM
12/23/14 11:06 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I think I'd buy a little more gear...
If you like drag racing, support your local track.
Re: Lots of shock questions lately [Re: Quicktree] #1700029
12/23/14 11:18 PM
12/23/14 11:18 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Just curious why fronts? What is your thinking behind this. If it spins at the hit on greasy track what would fronts help?
Re: Lots of shock questions lately [Re: 1967dartgt] #1700030
12/23/14 11:22 PM
12/23/14 11:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
because the 90/10s are going slam open bottom out and fall back down and unload the tires. maybe In am wrong, a little tire spin may not hurt him that much. he still has adjustment on the rear.
