Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699645
11/17/14 12:17 PM
11/17/14 12:17 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I called around and found out the SA Gear part number 78505T-9R
http://www.sagearinc.com/performance-products.php
While the cam and crank gears are Made in USA,
the double roller chain is made in India
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699646
11/17/14 09:21 PM
11/17/14 09:21 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
There's a guy in Oz who patented the Rollmaster timing gear set - he had exclusive rights to the aftermarket use of IWIS chains used in BMW/Benz etc...
India and China are always sending him chains to test, claiming they will be as good as the IWIS.
SO FAR..NONE HAVE BEEN.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Gen 3 Hemi timing chain? [Re: Moparmal] #1699647
11/17/14 09:43 PM
11/17/14 09:43 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Stock 6.1 chain works fine for me
Re: Gen 3 Hemi timing chain? [Re: hemidup] #1699648
11/24/14 08:28 PM
11/24/14 08:28 PM
NC
440Jim Offline
440Jim  Offline
NC
From what I've seen is that the tensioner slides or the tensioner plate will break before the chain will.
That is my understanding as well. The guide plate or the tensioner. I had the recall performed on my 2009 Challenger R/T. They changed everything (guide, tensioner, chain).
Re: Gen 3 Hemi timing chain? [Re: 440Jim] #1699649
11/25/14 02:10 AM
11/25/14 02:10 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
To my knowledge, The tensioner on the double roller sets only covers the first row of links, not both (the tensioner is the same size as the factory 6.1 piece). To me that is somewhat of a disadvantage. If someone made a beefier tensioner that was large enough for both links to ride on I would be interested. Until then I like the factory tried and true. Not to mention most of the fast modern Hemi guys run factory timing set.
Someone correct me if I am wrong on the tensioner being the same between single and double rollers please
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Gen 3 Hemi timing chain? [Re: Uhcoog1] #1699650
11/25/14 02:30 AM
11/25/14 02:30 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
The only timing chain I've ever used are Cloyes. I called them and they aren't making a double roller for a while.
I'm going to use the stock piece instead.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699651
11/25/14 07:26 AM
11/25/14 07:26 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I also installed a double roller, don't remeber the brand, but also had to grind the timing cover for clearance for the cam position sensor wheel.
Plynouth VIP '67 TT IC EFI
