4 door to 2 door question #1699311
11/15/14 11:47 AM
11/15/14 11:47 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I am thinking about doing a 4 door to 2 door conversion on a 64 Plymouth wagon. Is 64 Plymouth the only door that will interchange? Or will other years, or Dodge doors? I just need to know for sure before I start looking for a donor.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 4 door to 2 door question [Re: rattler] #1699312
11/15/14 12:21 PM
11/15/14 12:21 PM
Northeastern PA
Fanning Offline
Fanning  Offline
Northeastern PA
Doors from 1964 and 1965 Plymouth and Dodge 2 door post B body will work. Assuming this is a 1964 Belvedere wagon.
Re: 4 door to 2 door question [Re: Fanning] #1699313
11/15/14 07:45 PM
11/15/14 07:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
63 door fits but the latch is different. You can cut and weld the inside frame. Or use a 63 2 door as a donor and use the 63 B-Pillar for the conversion.
Doug
Re: 4 door to 2 door question [Re: dvw] #1699314
11/15/14 09:33 PM
11/15/14 09:33 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Thanks guys, I really would like to do the conversion, I just wasn't sure what year donors would work.
Now I know what to look for.
Re: 4 door to 2 door question [Re: rattler] #1699315
11/15/14 09:46 PM
11/15/14 09:46 PM
Minnesota
peabodyracing Offline
Minnesota
If I remember correctly the 63 windshield slant is different than 64. So the door will fit but the window frame portion would not.
Lead, follow or get the hell out of the way
Re: 4 door to 2 door question [Re: peabodyracing] #1699316
11/15/14 10:25 PM
11/15/14 10:25 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
63 door doesnt fit because the vent window has a different angle...
Re: 4 door to 2 door question [Re: savoy64] #1699317
11/16/14 11:23 PM
11/16/14 11:23 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Thanks guys. My new 64 Plymouth Savoy wagon just arrived today, this is the car I am considering changing to a two door. But my wife decided she likes the 4 door look. So, I might not convert.
Re: 4 door to 2 door question [Re: rattler] #1699318
11/16/14 11:24 PM
11/16/14 11:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Good for her. Absolutely nothing wrong with a four door.
Re: 4 door to 2 door question [Re: Alaskan_TA] #1699319
11/17/14 12:34 AM
11/17/14 12:34 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Other than 2 too many doors.
Don't be the exception.
Re: 4 door to 2 door question [Re: rattler] #1699320
11/17/14 02:17 AM
11/17/14 02:17 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Any pics?
Re: 4 door to 2 door question [Re: pushbutton] #1699321
11/17/14 03:39 PM
11/17/14 03:39 PM
dogdays Offline
dogdays  Offline
I hate cutting up a decent 2-door to change a wagon.
Silly me, I like the 2-doors better.
R.
Re: 4 door to 2 door question [Re: dogdays] #1699322
11/17/14 03:41 PM
11/17/14 03:41 PM
Out of the State of Confusion
blue_stocker Online rolleyes
blue_stocker  Online Rolleyes
x2 here, don't hack up a wagon either.
Re: 4 door to 2 door question [Re: rattler] #1699323
11/17/14 03:56 PM
11/17/14 03:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A cheap way to simulate a 2-door is simply remove the rear outside door handles.
Re: 4 door to 2 door question [Re: John_Kunkel] #1699324
11/17/14 11:05 PM
11/17/14 11:05 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Guys I wouldn't cut up a good car. I just thought if I found a rusty 2 door I might make the conversion. This is a really dry wagon. I just bought it from a member on here. Other than somebody doing a really bad paint job, I like the car. I can fix the color and drivetrain.
Re: 4 door to 2 door question [Re: rattler] #1699325
11/17/14 11:31 PM
11/17/14 11:31 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
By the way, while you are looking at my new project, tell me how to remove the paint from the aluminum trim without hurting it.
Re: 4 door to 2 door question [Re: rattler] #1699326
11/21/14 07:19 PM
11/21/14 07:19 PM
Minnesota
Minnesota
Glad you got that wagon. Great car, great buy, great seller. Have fun with it. Please don't convert it to a 2 door.
Re: 4 door to 2 door question [Re: peabodyracing] #1699327
11/22/14 02:15 AM
11/22/14 02:15 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
just got my 65 coronet bout finished. I was going to make 2 door but donor car prices are out of sight. mine has glass frt end, no inner fender panels, firewall back 12 in,motor back 9 in, rack and pinion, p/w,a/c,dana ladder bars,full cage,fact buckets and console,luggage rack, back seat, carpet and 543 motor. I would not make mine 2 door if I had to start over. I think laquer thinner will take paint off of chrome. all chrome is on my car except rocker moldings cause of removable frt clip. build it your way , the way you and wife want it. one of my best friends is doing 64 like yours and doing as 2 door,just don't look right. good luck rick
Re: 4 door to 2 door question [Re: rbkt65] #1699328
11/22/14 04:21 PM
11/22/14 04:21 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: 4 door to 2 door question [Re: GTX70sixpack] #1699329
11/22/14 04:23 PM
11/22/14 04:23 PM
Pataskala, Ohio
Pataskala, Ohio
70 GTX
70'cuda
Re: 4 door to 2 door question [Re: GTX70sixpack] #1699330
11/22/14 06:54 PM
11/22/14 06:54 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Thanks guys. I am thinking more and more of leaving it a 4 door. The look is kinda starting to grow on me. And it will be a lot less work for me too!
