Re: finally found solution to heating my garage [Re: bacaruda] #169857
12/19/08 01:14 AM
12/19/08 01:14 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My dad insulated his single car garage and didn't have much money left over to spend on a heater so he bought a 230v 18,000BTU portable contstruction heater. These past few days have been about the coldest it ever gets here and that heater gets the garage up to 50-55F so it's not bad at all, not super hot but very workable in a sweater and an extra pair of pants. He said some guru calculated the cost of that thing to be about 23 cents an hour. And you're only heating it while you're working in there so I don't think he'd ever spend more than 15 bucks a month heating that garage.
Re: finally found solution to heating my garage [Re: DaytonaTurbo] #169858
12/19/08 09:23 AM
12/19/08 09:23 AM
Eastern Ontario
shaker340 Offline
shaker340  Offline
Eastern Ontario
I have a Hot Dawg propane in my shop, it is very nice and heats my 30' x 48' shop quickly. I beleive my unit is either 60K or 80K.
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: finally found solution to heating my garage [Re: Tommy The Chryco] #169859
12/19/08 09:47 AM
12/19/08 09:47 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
When I lived in Michigan, I used a 150,00 BTU kerosene heater (torpedo type). It warmed the shop up nicely, but there was always that smell and quite a bit of noise. It also required a fresh air supply, so you couldn't close up the shop tightly or there would be carbon monoxide dangers. I am seriously considering one of the 99.9% propane units that are now available.
This is the land of the free because of the brave
Re: finally found solution to heating my garage [Re: rbstroker] #169860
12/19/08 12:42 PM
12/19/08 12:42 PM
pa
SixPackR/T70 Offline
pa
Im building this
Waste Oil Heater Plans
Transform a 55 gallon drum & 100# propane tank into Free Heat from a Zero Smoke Waste Oil Heater you can build in about 2 weeks.
* NO PANS TO CLEAN OUT
* NO FILTERS TO CHANGE
* NO FUEL NOZZLES TO PLUG
* NO EXPENSIVE PARTS OR MAINTENANCE
How is this heater different than other waste oil heaters?
Most waste oil heaters on the market today are engineered to be either a Spray Gun type or a Pot Burner. Pot burners are just what they sound like. It's basically an oil fire contained within a pan or pot. These are very dirty devices and create lots of soot and smoke. Spray gun types are a more efficient design because atomizing the fuel before igniting it results in a much cleaner burn and more heat output. The problem is the high pressure fuel pumps and tiny fuel spray nozzles that plug up due to the particles and contaminants present in waste oils. Our heater atomizes the fuel before igniting it but does not use a high pressure pump or fuel nozzle, there is nothing to plug up and the design eleminates the need for expensive filter changes.
· Heating Capacity:
70,000 Btu’s - 200,000 Btu’s (with adjustable fuel feed)
· Fuel Consumption:
0.6 to 2 gallons per hour
· Fuels:
-Waste Motor Oil
-Waste Vegetable Oil
-Transmission and Hydraulic Oils
-Mineral Spirits
-Machine Cutting Oils
-Synthetic Oils
-Gear Oils.
-BioDiesel or Fuel Oil at any ratio together or separately.
· Dimensions:
30” Diameter x 68" Tall + Fuel Tank of your choice.
· Weight:
~250 Lbs. (Without Fuel Tank).
· Electrical:
110 VAC / 15 Amp Circuit.
· Compressed Air:
Less than 0.5 CFM @ 80psi
· Controls:
Manual Ignition and Shutdown
· Construction:
Commonly available materials
Re: finally found solution to heating my garage [Re: cudabitten] #169861
12/19/08 01:00 PM
12/19/08 01:00 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I bought an electric heater from Grainger (18000) BTU, only catch was, (and I was avoiding)I had to install a 240v/30 outlet plus a 30 amp breaker. Now the garage stays at about 55 degrees while I'm not working out there and I can turn the thermostat up and get it to stay at 65 degrees while working. It only took 30 minutes to move from 45 to 60 degrees. Just wanted to follow-up to anyone who is still having problems.
I need to do something like this. My garage is 24x40 and insulted so I'm wondering what size I would need to heat it kind of like yours. 18000 BTU's enough? Thanks.
Actually, all three electric heaters I purchased were rated in BTU'S not kwatts. Its good to compare BTUS's when comparing propane with electric. The It dosent matter what it stands for as long as you know that 18000 BTU's is rated to heat a 500 square foot space. I leaned this the hard way by going cheap at first with the 5000 BTU heaters. It wasnt until I purchased the 18000 BTU propane heater that I realized the difference in heating potential. My garage is only a 20 x 20 = 400 square feet but I oversized the heater slightly so it wouldn't run as often. Like I said I went to three different stores, and returned three heaters until I got the right match. this heater is only 16" by 12" by 12". My garage is insulated as well. However your garage is 960 square feet. Its easy to figure out what heater size you need just go to the grainger web site and read the descriptions. They will tell how many BTU's the heaters are and what size garage they will heat. You might want to get two smaller units and heat from opposite directions.
1) No need to keep going back and forth trying to figure out what size heater you need. Again;
http://www.ultimategarageheater.com/garage-heater-calculator.php
you will note that your 400sq ft. garage (insulated) needs about 4.4kw (approximately 15,000 BTUH) for a 60 deg F temperature change.
2) All commercial electric heaters are rated in KW, but no matter as long as you realize that 3414 BTUH = 1kw it's simple math to go back and forth.
3) ratings per square foot are pretty rudimentary (even more so than the simple calculator I linked above) and doesn't take into account ceiling height, insulation, # and type of doors and windows, exposure, etc, etc.
Just my as I do this for a living.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: finally found solution to heating my garage [Re: DaytonaTurbo] #169862
12/19/08 01:20 PM
12/19/08 01:20 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
This is exactly what I am using,230V/30A 18000 BTU portable and it does seem to be working well. I dont have any propane to buy, no poisonous gases,no kerosene to buy or smell. I just set the thermostat, and it works by itself. With the propane heater that I already returned, the propane canisters cost me 6 dollars for 2 one lb cans, which last for 6 hours total. So I dont think the electric will be that much more to operate. The biggest obstacle was installing the breaker, 10ga wire, and 30A receptacle. Thankfully I have some electrical experience and was able to install this stuff myself in about 2.5 hours. Still a pain though, crawling in the garage attic in 35 degrees.
Re: finally found solution to heating my garage [Re: cudabitten] #169863
12/19/08 01:36 PM
12/19/08 01:36 PM
eastern, pa.
eastern, pa.
This is good info ...
Thanks,
Chris.
Re: finally found solution to heating my garage [Re: DPelletier] #169864
12/20/08 07:08 PM
12/20/08 07:08 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
to figure size of heater needed..multiply square footage by ceilg height..(cubic feet now) and then multiply that by 5.5 to 6.0 for the BTU size heater needed..example.600 sq foot room with 8 foot ceiling would be 4800 cubic feet by 5.5 is 26,400 so at the low end or minimal size heater a 27000 btu heater would heat it..4800 times 6 is 28,800 so a 28,800 btu heater at the max ( for efficiency) would work very well. too small will not heat a room well enough...too big will use more fuel than needed to do the job so try to stay close
Re: finally found solution to heating my garage [Re: cudabitten] #169865
12/20/08 08:14 PM
12/20/08 08:14 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I have a hawt dawg I think thats how the company spells it. It has worked great over the last 8 years, but if I was to build my shop over I would do in floor radiant heat.
My friend installed this in his shop and the comfort in that shop is amazing, you walk in and the warmth is just part of you and your feet never get cold from the concrete as the heat is coming from the floor.
Re: finally found solution to heating my garage [Re: boydsdodge] #169866
12/20/08 11:24 PM
12/20/08 11:24 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I would use infra red heat..very efficient and heats fast/well
Re: finally found solution to heating my garage [Re: terzmo] #169867
12/22/08 05:01 PM
12/22/08 05:01 PM
DPelletier Offline
DPelletier  Offline
Re: finally found solution to heating my garage [Re: DPelletier] #169868
12/27/08 12:35 AM
12/27/08 12:35 AM
Omaha
DEMONIC Offline
DEMONIC  Offline
Omaha
My advice is an will always be. Do what you can with what you got. If you set up a few different ways to heat your garage you can switch between whichever is most efficent and safe for whatever you are working on. I have radiant heat, kerosene heater, infared lamps, and a couple of space heaters. If I was building a shop or did not have any heat set up yet I would consult Dave (there is no substitute for knowledge from someone who does something for a living)
My advice is to have at least two different ways to heat your garage.
Re: finally found solution to heating my garage [Re: DEMONIC] #169869
12/27/08 11:42 AM
12/27/08 11:42 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I was going to buy a Mad Dawg heater but found a good deal on a near new heat and air unit. It cost about $100 more than the Mad Dawg and I have air conditioning too. The duct work was about $400 including the programmable thermostat.My shop is 36' X 54' with 12' walls and no ceiling, it is insulated and I have a fan pushing the warm air down from the attic space. The thermostat is set on 50*, when I go out to work I raise it to 55*.
