Re: exhaust is so potent it hurts my throat
[Re: cal_gecko]
#1696737
11/10/14 02:41 PM
11/10/14 02:41 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"something is spraying on the front drivers side of the engine" Hope it is not a head gasket leaking from that side of the motor Mike
[Re: cal_gecko]
#1696739
11/10/14 03:00 PM
11/10/14 03:00 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
something is spraying on the front drivers side of the engine ... not sure where it's coming from ... there's not really anything over there! White deposits from... something.
Bring it to OT, and get the pressure-tester out...
[Re: Supercuda]
#1696740
11/10/14 03:02 PM
11/10/14 03:02 PM
Posts: 3,916 usa
lewtot184
usa
anti-freeze/water?
Those plugs would be steamed clean if that was the case.
not necessarily. looks like lime on the plugs to me.
[Re: Beebuzzn]
#1696742
11/10/14 07:27 PM
11/10/14 07:27 PM
Posts: 5,163 CT
GTX MATT
CT
The fuzzyness is from fuel additives
[Re: GTX MATT]
#1696743
11/10/14 10:09 PM
11/10/14 10:09 PM
Posts: 7,664 IN
ahy
IN
... Or oil additives. I have seen similar on an engine with lose valves, poor seals and high oil consumption.
[Re: RapidRobert]
#1696746
11/12/14 05:03 AM
11/12/14 05:03 AM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
That's what I'd do, pump it up to 15 when hot and do a compression test. I believe that'll uncover something
can you please explain? I thought the pressure tester was for the cooling system? How will doing a cooling system pressure check while doing a compression check show something?
[Re: cal_gecko]
#1696747
11/12/14 05:39 AM
11/12/14 05:39 AM
Posts: 1,235 Phoenix, AZ
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
I guess that you missed the post regarding the white specks on the engine and it possibly being a coolant issue. A cooling system pressure check may display a leak which may have led to the white specks.
[Re: Jjs72D]
#1696748
11/12/14 05:55 AM
11/12/14 05:55 AM
cal_gecko
Sacramento, CA
OK... I can understand how doing a cooling system pressure check would help determine if that's an issue.. but how could doing a compression check at the same time show something? Just trying to understand what I'd be looking for ...thanks!
[Re: cal_gecko]
#1696750
11/14/14 10:30 PM
11/14/14 10:30 PM
RapidRobert
Cal we were sayin to do the compression test AND the coolant pressure test (not at the same time). Not sure if the plug ain't firing or if it is fouled but I'd toss another one in (other 7 wouldn't hurt also) & see how it acts & I'd still do the pressure and compression tests cuz didn't you say earlier that something up front was sprayin out on the fender? EDIT I reread & it DID sound like I was sayin to do both at the same time
