Re: Am I wrong on pricing?
[Re: markfh52]
#1695337
11/07/14 12:12 AM
11/07/14 12:12 AM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
going rate around here is 50-75/each
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: markfh52]
#1695341
11/07/14 11:15 AM
11/07/14 11:15 AM
Challenger 1
Cincinnati, Ohio
What type of rims are we talking about. Are they rust-free, 'cause soda won't touch rust. If they're done with soda then they have to be properly cleaned afterwards for the paint to stick.
I guess what I'm getting at is have you done your research or are you just reading magazine articles and figure soda and paint is the hot ticket.
Whatever the case, I think you could have a dozen rims blasted and painted for $500.00 and expect change !!
The rims are stock on my 68 GTS. Yes, there is a little surface rust on them and I have evapo-rust to take care of it.
My research consist of many sources including you. My mention of soda was mainly based on research and recommendations for something that will not remove metal as I want the original surface and to preserve all markings on the rims. From what I've read I do remember that soda has to be properly cleaned off before painting.
I want paint to keep the rims original looking.
If there is a better media to use please enlighten me. Like I said and I'm learning. Any help is appreciated.
Just have them sand blasted and then paint right over that and don't touch them after sand blasting them before paint.
It will not hurt the stampings in the rims. I have sand blasted many, many rims over the years with sand and coal slag. Like about 50 or more and even big truck rims. I did 24 mopar rims all at once a few years ago.
Don't mess around with chemicals and soda if you have rust.
Did I mention not to touch them after blasting before paint?
On the price...what kind of paint is being used? With today's paint cost 500 is not that bad. Maybe sand blasting would be cheaper than soda? It would be for me, because I sand blast all the time.
[Re: mattsmopars]
#1695343
11/07/14 12:26 PM
11/07/14 12:26 PM
Posts: 8,862 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
He means "with bare hands" and this can't be stressed enough.
[Re: Stanton]
#1695344
11/07/14 12:31 PM
11/07/14 12:31 PM
Challenger 1
Cincinnati, Ohio
Yes and I mean it don't need to be wiped off with lacquer thinner or anything like that before painting if they are media blasted and not soda blasted. Just blow em off with a air hose and prime.
[Re: MOPARMIKE69]
#1695347
11/07/14 12:39 PM
11/07/14 12:39 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Single stage gloss black on the inside...
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1695348
11/07/14 12:40 PM
11/07/14 12:40 PM
MOPARMIKE69
Nashville, TN
Base coat clear coat body color outside.
