deck plate hone on a filled block... #169492
12/17/08 08:25 PM
12/17/08 08:25 PM
organ
maximum entropy Offline OP
organ
is it necessary to deck plate hone a filled block? it seems to my pea brain that it wouldn't be.
Re: deck plate hone on a filled block... [Re: maximum entropy] #169493
12/17/08 08:28 PM
12/17/08 08:28 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Yes.
Re: deck plate hone on a filled block... [Re: maximum entropy] #169494
12/17/08 08:29 PM
12/17/08 08:29 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With or without always use torque plate for a new finish hone.
Re: deck plate hone on a filled block... [Re: maximum entropy] #169495
12/17/08 08:30 PM
12/17/08 08:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have mine done(with the plates) after filling
the block. Some say they have measured the change,
I'll take their word for it
Re: deck plate hone on a filled block... [Re: MR_P_BODY] #169496
12/17/08 08:39 PM
12/17/08 08:39 PM
organ
organ
cool. thanks guys. let the quest for perfection resume!
Re: deck plate hone on a filled block... [Re: maximum entropy] #169497
12/17/08 11:17 PM
12/17/08 11:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
Carl, I have BHJ torque plates for both the B-RB and 426 Hemi(sold the SB one last year)and a lot of head gaskets, let me know if you want to use it. BTW, I hate filled blocks
Re: deck plate hone on a filled block... [Re: Cab_Burge] #169498
12/18/08 12:16 AM
12/18/08 12:16 AM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
Absolutely a must!
Jeff Day
Precision Automotive Machine, INC
Canton, Ohio
Re: deck plate hone on a filled block... [Re: jdfpam] #169499
12/18/08 12:54 PM
12/18/08 12:54 PM
Locomotion Offline
Locomotion  Offline
You have to remember that most of the thread engagement and resulting distortion is towards the top 1/2 of the bore. Blocks are not usually filled to the top, but it will affect it anyway.
It also wouldn't hurt to torque the main caps before honing with a plate also!
Re: deck plate hone on a filled block... [Re: Locomotion] #169500
12/18/08 01:06 PM
12/18/08 01:06 PM
I even went a step further and torqued a head down as well as the mains while the block fill was seting up. Probably overkill
Re: deck plate hone on a filled block... #169501
12/18/08 05:03 PM
12/18/08 05:03 PM
Locomotion Offline
Locomotion  Offline
If you have the time, patience and/or money, why not! I've heard of plates bolted on both side for setting up as well as honing. Even heard a rumor of someone running hot water through it!
