Anybody convert a 65 cable shift car......? #1694721
11/05/14 12:22 PM
11/05/14 12:22 PM
mesa,az.
wedgepower Offline OP
mesa,az.
.....to 66 and newer tranny?
My woman just bought herself a 65 Fury 1 with a 383 auto. The tranny is sloppy. I have several 66 and newer trannys to choose from. I found this product from A&A that looks good. Any input?
http://www.aandatrans.com/Products/Colum...cle__AACCC.aspx
Re: Anybody convert a 65 cable shift car......? [Re: wedgepower] #1694722
11/05/14 12:47 PM
11/05/14 12:47 PM
Andrewh Offline
Andrewh  Offline
http://www.imperialservices.net/Cparts.html
middle to end of the page is the only other choice I am aware of.
never done it, but thought about it.
also noticed that the newer van's 90's seem to have a "cable" type shift in their columns and thought about seeing how that might work too.
Re: Anybody convert a 65 cable shift car......? [Re: wedgepower] #1694723
11/05/14 01:44 PM
11/05/14 01:44 PM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
I used imperial's cables when I put a newer 727 in my '65 belvedere II. It's a good kit, not too miserable to install and adjust. But it took over 6 months for them to send it to me. The main reason I did the trans swap was to run a newer style valve body, IMO that was the only bonus.
In order to know what you want, you'll probably have to find out what you don't want.
Re: Anybody convert a 65 cable shift car......? [Re: fshd4it] #1694724
11/05/14 02:26 PM
11/05/14 02:26 PM
mesa,az.
mesa,az.
The 65and earlier 727s had a different input shaft, therefore a different converter which is harder to get.
This is my first step towards a 518 swap in the future.
Re: Anybody convert a 65 cable shift car......? [Re: wedgepower] #1694725
11/05/14 04:27 PM
11/05/14 04:27 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
You would have to check it out but a 66 Fury column and linkage might bolt in and be the cheapest. It may not be concourse correct but doesn't sound like that is a concern.
I stayed with the cable shift in my 65 C body and some days wish I hadn't. It works good and everything but it just seemed like I spent a lot of money on it by the time I replaced the shift and park cables. Different converter, etc etc
Re: Anybody convert a 65 cable shift car......? [Re: wedgepower] #1694726
11/05/14 04:49 PM
11/05/14 04:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For the $160 cable conversion (add $100 for the conversion trans mount) you're close to the cost of overhaul parts for the '65 trans.
Re: Anybody convert a 65 cable shift car......? [Re: wedgepower] #1694727
11/05/14 04:53 PM
11/05/14 04:53 PM
Missoula, Montana
ChadP Offline
ChadP  Offline
Missoula, Montana
I have a 727 cable shift transmission that I took out of my 65 Coronet when I converted to 4-speed. The transmission worked great when I removed it 3 years ago, and it's been stored in heated garage since then. I'm located in Missoula, MT. If you are interested, send e-mail to cparrish1965@hotmail.com.
'65 Coronet 500
Re: Anybody convert a 65 cable shift car......? [Re: ChadP] #1694728
11/06/14 12:21 AM
11/06/14 12:21 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
We used the imperial services kit on my dad's 65 coronet with a 66 trans (the 66 has the same spline pattern, so he used the same converter that was with the 65 trans).
We are using a manual valve body in the 66 trans.
It works OK, we have tried adjusting every which way and can't get it perfect. As it is now, the 2-3 shift requires pushing the shifter a bit further towards neurtral than should be. But it's not a race car, so it's livable..
I'd give the A&A one a try if I had to do it again.. maybe the geometry or something is better than the imperial services one. Or it could be the exact same. I didn't even think imperial services was in business anymore..
Re: Anybody convert a 65 cable shift car......? [Re: Exit1965] #1694729
11/06/14 02:54 AM
11/06/14 02:54 AM
mesa,az.
mesa,az.
I called A&A and talked to a guy. He seemed knowledgeable and was good on the phone, so I ordered one.
I weighed my options and considering I have a fresh newer tranny and I plan a 518 swap before too long updating now makes the most sense.
Thanks for the input fellas.
