Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Trick Flow introduces BBM heads [Re: Troy] #1694263
11/14/14 05:54 PM
11/14/14 05:54 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I was happy to see a new product come out for any Mopar engine. Heads, blocks and anything is nice to see. It means that the Mopar market is growing and that gives us all more options.
Maybe TF will come out with a B-engine EFI manifold for the 451-496 guys, that market has been totally ignored. I probably wouldn't buy one, but other guys would be glad to get them, and I'd be glad they were out there if I was ever needing one.
Re: Trick Flow introduces BBM heads [Re: Hot 340] #1694264
11/14/14 06:31 PM
11/14/14 06:31 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Come on Jimmy, you aint got nothing fast.
I cannot debate this.
Re: Trick Flow introduces BBM heads [Re: jim sciortino] #1694265
11/14/14 08:22 PM
11/14/14 08:22 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
for all intensive purposes we all get aggrevated when we reach a performance level and hit the wall for lack of available parts.the new trick flow heads appear to have great quality and potential for those who use them.all the better.its very hard to understand why the mopar block situation has reached this level at all considering that block castings have been around since horses were delivering milk and nobody except kb can get it right in 2014.i dont think anybody here was or is bashing new parts,just the lack of higher level performance parts.i for one hope that these new parts are like chinese resturaunts,when one pops up,in 30 days there will be 75 more.the ultimate goal for everyone is to go faster....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Trick Flow introduces BBM heads [Re: dakotawilly] #1694266
11/14/14 10:23 PM
11/14/14 10:23 PM
Trumbull,CT.
Trumbull,CT.
Exactly....
There isn't an individual in this thread that responded negatively to any of my posts that can point to a single "bash" of the Trick Flow head on the merits of the head on my part, as their subsequent posts prove.
Hence, my questioning of their blatant lack of comprehension. Obviously, it's easier to respond to your own musings than to those of someone you take issue with.
I drive around town in a 2550# backhalf Dart with a 900hp N/A small block that's as nice as ANY Dart on this forum and a 1620hp screw blown HEMI in a composite round tube Cuda', that's as nice as ANY Cuda' on this forum. I'm not sitting around playing with myself (well.....maybe sometimes). I buy parts.....and cannot believe there hasn't been a SINGLE modern upgrade after the long in the tooth straight head W8, PSO, or the Millennium HEMI.
Chevy is at a 60 handicap against Ford in the bore space department, yet that has not stopped the performance aftermarket from developing countless heads able to reach any desired power level attainable with current technology. We are "only" 40 less than Chevy compared to Chevy being 60 less than Ford and in some cases our aluminum blocks CAN be ordered in 4.840. Of course for economic reasons nobody in their right mind would expect a flow of hardware Ford and Chevy enjoy.......but to not have a SINGLE option better than the outdated W8, PSO, or Millennium HEMI (which is far less affected by bore space with it's opposed valves), unless ones decides to build a Pro Stock big, or small block and has ZERO options when it comes to a modern CG, or iron block casting, is absolutely insane.....in my opinion.
Especially when you consider the Pontiac engine is saddled with laughable factory bore spacing, EXCEPT when machined in specialized fashion, yet they have access to iron blocks and aluminum heads that are more current than MOPAR offerings.
No offense to Trick Flow for making a sound business decision for the company, but as time goes on and the parts situation becomes WORSE instead of better, it's aggravating. This is MOPAR for Christ sake. A company with a championship heritage in motorsports......not Tucker.
Re: Trick Flow introduces BBM heads [Re: jim sciortino] #1694267
11/14/14 10:33 PM
11/14/14 10:33 PM
Did you not Comprehend what this thread was about ????
It says right in the title
Re: Trick Flow introduces BBM heads [Re: ] #1694268
11/14/14 10:41 PM
11/14/14 10:41 PM
Trumbull,CT.
Trumbull,CT.
Perfectly.....
What's your point.......that unless I gushed over a yet another head that overlaps existing offerings performance wise, commenting is off limits somehow???
Re: Trick Flow introduces BBM heads [Re: jim sciortino] #1694269
11/14/14 10:45 PM
11/14/14 10:45 PM
Perfectly.....
YOUR Comprehension continues to be way off.....you are going off on a tangent again.
Go polish your show cars, might relieve some of your pent up hostilities
Re: Trick Flow introduces BBM heads [Re: ] #1694270
11/14/14 11:05 PM
11/14/14 11:05 PM
Trumbull,CT.
Trumbull,CT.
Perfectly.....
Another one who can't answer a simple question.
Wanna take a crack at one of the "show" cars???
I'm easy to find on the Rt. 25 connector.
Re: Trick Flow introduces BBM heads [Re: jim sciortino] #1694271
11/14/14 11:23 PM
11/14/14 11:23 PM
jersey
Spaceman Spiff Offline
jersey
Perfectly.....
I'll be your DP man.... $500 for $5,000 sound about right?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Trick Flow introduces BBM heads [Re: jim sciortino] #1694272
11/14/14 11:40 PM
11/14/14 11:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
you do have a pretty nice "show" car Jim. Love that small block Dart.
Re: Trick Flow introduces BBM heads [Re: J_BODY] #1694273
11/14/14 11:47 PM
11/14/14 11:47 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'll sum up this thread. Let me see if I got this straight?
Re: Trick Flow introduces BBM heads [Re: Brian Hafliger] #1694274
11/15/14 12:03 AM
11/15/14 12:03 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Unlike every single mopar head out there, these heads are a TRUE bolt on!
And they actually flow as advertised...and they have upgraded hardware.
This is the first of 3 heads they will offer...
Take note what they flow, the quality castings, machine work and parts, then compare them with Eddy or whoever's heads. You'll quickly see they are priced damn good!
Hey, Brian. I was wondering what makes the Trick Flows more of a bolt-on than the RPM, Stealth, Sidewinder, et al heads that are flooding the market? I like the better combustion chambers, but I'm not quite ready to yank my IMM massaged RPMs off for a set of Quick Flows- just yet anyway.
I'll not complain about competition or question the T.F. marketing strategy. I'm sure they have a marketing team that knows more than I about selling heads. It makes sense to me to start selling heads that have a market of 1000s as opposed to a PSO/Predator killer with a market of 10s. Especially with the other limitations of the B/RB wedge noted by persons that know far more about that than I do.
Re: Trick Flow introduces BBM heads [Re: J_BODY] #1694275
11/15/14 12:04 AM
11/15/14 12:04 AM
Trumbull,CT.
Trumbull,CT.
Thanks....
I almost considered taking it to a car show once.
And again.....I have no desire, nor was it my intention to demean Trick flow, or their new product. Just venting on the state of the MOPAR aftermarket.......or lack thereof. In hindsight, I probably should have done it in a dedicated thread.
As for anyone who was offended.......oh well.
Re: Trick Flow introduces BBM heads [Re: RobX4406] #1694276
11/15/14 12:05 AM
11/15/14 12:05 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
They should eliminate the quote option. It would stop some of this BS and make the thread easier to read.
Re: Trick Flow introduces BBM heads [Re: B1HEAD_USER] #1694277
11/15/14 12:20 AM
11/15/14 12:20 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
All someone needs to do is take one of these heads with some good valvetrain+ 20psi and go run 8's. Yep.
Mopar to the bone!!!
Re: Trick Flow introduces BBM heads [Re: Skeptic] #1694278
11/16/14 04:50 PM
11/16/14 04:50 PM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
Able to run 3/8 pushrods with no clearancing, no touch up valve job, no touch up guide honing needed, much higher quality spring/retainer/lock combo, higher quality valves, no porting necessary....all of the fore mentioned heads need some work to be right...requiring more money and time wasted.
Brian Hafliger
Re: Trick Flow introduces BBM heads [Re: Brian Hafliger] #1694279
11/16/14 07:03 PM
11/16/14 07:03 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
3/8" pushrods bewdy - after grinding my 2nd set of stealths I still had to go 5'16" pushrods
it is good to see company come to the fore with product .
Hey where i live it is hard enough getting a decent cam off the shelf let alone choice of heads .
You fellas have got it easy so stop complaining . Wanting new blocks - just getting an old 440 block you have to pay like it was solid gold here .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow introduces BBM heads [Re: Brian Hafliger] #1694280
11/18/14 12:17 AM
11/18/14 12:17 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Thanks for the reply It's good to see more quality options for these obsolete motors.
Re: Trick Flow introduces BBM heads [Re: Skeptic] #1694281
12/20/14 07:55 PM
12/20/14 07:55 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
When are these going to be released?
Looking to buy a pair.
Re: Trick Flow introduces BBM heads [Re: GY3] #1694282
12/21/14 04:27 AM
12/21/14 04:27 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I've said for years that if anybody ever needed a pair/set, it was you...
