which chemical best 4 cleaning sap and crud from glass #1693803
11/03/14 07:50 AM
11/03/14 07:50 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Ive got a windshield covered in sap, paint dust from sanding and other crud that's really fused itself good. Windex aint cuttin it
I have laquer thinner, acetone, mineral spirits and denatured alcohol. Im sure most of them will cut through everything on the windshield with ease, Im just not sure if any of them might damage/fog the glass.
Which should I use?
Re: which chemical best 4 cleaning sap and crud from glass [Re: Adam71Charger] #1693804
11/03/14 09:39 AM
11/03/14 09:39 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Any of the chemicals you mentioned will work and shouldn't hurt the glass. I've used lacquer thinner myself on my windshield (outside) to get various crap off of it and it never fogged the glass.
When I pulled my old rear glass I SOAKED it in lacquer thinner and scrubbed to get all that old sealer off the edges and the glass is fine.
If you are still scared, try 50/50 ammonia/water mix which is basically Windex on steroids. Wear gloves for that...
I think you will be fine.
Re: which chemical best 4 cleaning sap and crud from glass [Re: cjskotni] #1693805
11/03/14 01:23 PM
11/03/14 01:23 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When I used to work out in the shop running a wood saw, I would get tree sap on my hands all the time. The only thing that would remove it was WD-40.
Re: which chemical best 4 cleaning sap and crud from glass [Re: burdar] #1693806
11/03/14 01:33 PM
11/03/14 01:33 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Hands down the best stuff I've ever used:
http://www.glazedistributing.com/glaze.html
Last item on the page. I have a 70' blue spruce in my front yard and always have to clean sap. This wipes it right off like it's not even there.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: which chemical best 4 cleaning sap and crud from glass [Re: herkamer] #1693807
11/03/14 08:45 PM
11/03/14 08:45 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
I've heard Pine Sol takes off sap.
Re: which chemical best 4 cleaning sap and crud from glass [Re: Powerflow] #1693808
11/03/14 09:59 PM
11/03/14 09:59 PM
IN
ahy Offline
ahy  Offline
IN
I have used lacquer thinner for glass. Cleans well with minimum abrasion and does not hurt the glass. Just be very careful as it will hurt surrounding paint, plastic or rubber. I keep the can well away from the car and just wet the corner of a rag... do a small area at a time.
Re: which chemical best 4 cleaning sap and crud from glass [Re: ahy] #1693809
11/04/14 11:28 AM
11/04/14 11:28 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
bar keepers friend
Re: which chemical best 4 cleaning sap and crud from glass [Re: DJVCuda] #1693810
11/04/14 07:34 PM
11/04/14 07:34 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
lacquer thinner
Keep it off the paint.
Re: which chemical best 4 cleaning sap and crud from glass [Re: Adam71Charger] #1693811
11/04/14 08:46 PM
11/04/14 08:46 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
razor blades work well for me.
Re: which chemical best 4 cleaning sap and crud from glass [Re: Adam71Charger] #1693812
11/05/14 12:54 AM
11/05/14 12:54 AM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Like dissolves like. So, for tree sap, you want a pine terpene or an orange terpene. Pine Sol is one, Goof Off is d-limonene (from oranges). Neother will hurt paint and both are relatively safe on your hands. PineSol will rinse with water and the Goof Off you could use some good detergent afterwards. ( I cleaned defense products for 35 years so I know some good cleaning stuff. :).
Tom
Re: which chemical best 4 cleaning sap and crud from glass [Re: Dan Halen] #1693813
11/05/14 12:27 PM
11/05/14 12:27 PM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: which chemical best 4 cleaning sap and crud from glass [Re: an8sec70cuda] #1693814
11/05/14 09:43 PM
11/05/14 09:43 PM
Locomotion Offline
Locomotion  Offline
Use a non-scratching pot scrubber/sponge to scrub with.
Re: which chemical best 4 cleaning sap and crud from glass [Re: Locomotion] #1693815
11/09/14 10:32 PM
11/09/14 10:32 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Fast Orange hand cleaner. I had some 30 year old crud on a back window that nothing would remove not even thinners. The local glass shop told me to use this trick it worked great.
Re: which chemical best 4 cleaning sap and crud from glass [Re: maximus] #1693816
11/10/14 12:17 AM
11/10/14 12:17 AM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
FAst Orange has some d-limonene (orange terpene) and it makes good sense it would work well too. Thanks for the tip!
Re: which chemical best 4 cleaning sap and crud from glass [Re: Tom Hand] #1693817
11/10/14 12:47 AM
11/10/14 12:47 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Doesn't fast orange also have grit in it? I'd worry about scratching or fogging the glass.
Re: which chemical best 4 cleaning sap and crud from glass [Re: stumpy] #1693818
11/10/14 02:57 AM
11/10/14 02:57 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I've used WD-40 with good success.
