quick release steering wheel coulper for stock column? #1693552
11/02/14 04:19 PM
11/02/14 04:19 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
does anyone make a quick release steering wheel coupler for a stock 72 e body steering column? I'm finding several weld on for 3/4" stock? thanks guys!
Re: quick release steering wheel coulper for stock column? [Re: upnover] #1693553
11/02/14 04:25 PM
11/02/14 04:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.jegs.com/i/JEGS/555/60724/10002/-1
I have two of those in use with A body steering columns.
Tony
70 AARCuda Vitamin C
Re: quick release steering wheel coulper for stock column? [Re: 70AARcuda] #1693554
11/02/14 04:35 PM
11/02/14 04:35 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
exactly what I was looking for, thank you!
Re: quick release steering wheel coulper for stock column? [Re: 70AARcuda] #1693555
11/02/14 04:48 PM
11/02/14 04:48 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Could I make it work with my stock steering wheel? I like the factory look
Re: quick release steering wheel coulper for stock column? [Re: 70AARcuda] #1693556
11/02/14 04:52 PM
11/02/14 04:52 PM
Canada
onig Offline
onig  Offline
Canada
What mods need to be done?
69 Dart
Re: quick release steering wheel coulper for stock column? [Re: onig] #1693557
11/02/14 05:09 PM
11/02/14 05:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
mine is a B body. I used a similar coupler and gutted the upper shift bowl. The portion where the shift handle attached was opened up to access the release button. Then I spun a 1/8 aluminum disc and tacked it to the hub. I epoxied the bowl to the disc since it was pot metal. Here's the results.
Doug
Re: quick release steering wheel coulper for stock column? [Re: dvw] #1693558
11/02/14 05:10 PM
11/02/14 05:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
glued together
Re: quick release steering wheel coulper for stock column? [Re: dvw] #1693559
11/02/14 05:12 PM
11/02/14 05:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The wheel bolts to the adapter with the 3 threaded holes. The hex is welded to the shaft. To reduce weight the shaft is 3/4" x .090" moly tubing.
Doug
Re: quick release steering wheel coulper for stock column? [Re: dvw] #1693560
11/02/14 05:13 PM
11/02/14 05:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Who would notice?
Re: quick release steering wheel coulper for stock column? [Re: onig] #1693561
11/02/14 05:26 PM
11/02/14 05:26 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i have one of those and had to dress the splines a little bit to get it to slide on a stock shaft.
fwiw i believe the wonderful nhra states any QR adapter must be welded. of course there's only a bazillion cars out there with the steering wheel bolted on. maybe it would be ok if they required an nhra approved steering wheel tether at $200 a copy
Re: quick release steering wheel coulper for stock column? [Re: dvw] #1693562
11/02/14 05:30 PM
11/02/14 05:30 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I bolted the quick release to back of the steering wheel. The portion that stays on the column. I had welded to the orignal nut down inside the can. Cut a slot for the button (wich I extended) to poke out
I used a 72-74 e body steering wheel only so I could mount my trans brake button
Also used a t style male/female wire connection out of a old wire harness so the wheel could be moved freely when not driving
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: quick release steering wheel coulper for stock column? [Re: toplescuda] #1693563
11/02/14 05:48 PM
11/02/14 05:48 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
With wheel on
1971 charger
