Correct colour code for 1969 (F6) Dodge Bright Green #1693103
11/01/14 05:15 AM
11/01/14 05:15 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey guys can anyone provide the correct code for this colou
Also, I believe 1969 Spring Green was similar but actually a different colour to F6 Bright Green (looks darker to my eye and not as bright) can anyone advise?
Thanx !
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: LAD 524] #1693104
11/01/14 09:55 AM
11/01/14 09:55 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
There seem to be many different shades of F6 depending on the recipe that you use. In an effort to be as accurate as possible, I color mapped the bottom of an original F6 Lynch Road deck lid.
The recipe is in the pictures below. I used a base coat clear coat system. Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: Big D A12] #1693105
11/01/14 09:57 AM
11/01/14 09:57 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Finish product.
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: Big D A12] #1693106
11/01/14 10:56 AM
11/01/14 10:56 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
looks great thanx for the info - Im after a mix that will give it the brightest look I can get.
In some pix its looks really bright, crisp and pops, in others not so much. Do you have any pics of it in the sun ?
Heres what Im really after :
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: LAD 524] #1693107
11/01/14 11:13 AM
11/01/14 11:13 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here are the original F6 paint codes, however I have heard that paint suppliers cannot use them now.
Courtesy of hamtramick-historical;
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: LAD 524] #1693108
11/01/14 01:08 PM
11/01/14 01:08 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Thanx !
Here are two threads that have that mentioned. If you do a search for "F6" in the Google custom search box, you may find several more.
https://board.moparts.org/ubbthreads/showflat.php?Number=6216267
https://board.moparts.org/ubbthreads/showflat.php?Number=5371520
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: moparfan53] #1693109
11/06/14 09:14 AM
11/06/14 09:14 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Still a,ittle confused.
Is Spring Green (rarer green color) and Dodge Bright Green (A12) the same color?
If anyone can help, it'll be much appreciated !!
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: LAD 524] #1693110
11/06/14 05:53 PM
11/06/14 05:53 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I believe Spring Green is a Plymouth color
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: Morty426] #1693111
11/06/14 07:36 PM
11/06/14 07:36 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Correct, and they are slightly different. F6 is a little lighter than code 97 Rally Green......
Admiration For Multiple Carburetor Vehicles...
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: Stewpar] #1693112
11/07/14 12:37 PM
11/07/14 12:37 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Rallye Green is a '69 Camaro color. gaaaaack!!
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: RestoRick] #1693113
11/07/14 07:35 PM
11/07/14 07:35 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Easy there RK!
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: Stewpar] #1693114
11/07/14 10:23 PM
11/07/14 10:23 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Easy there RK!
HAHA I actually thought they were the same !
anyone know the PPG colour/paint codes for 69 Plymouth Spring Green and 69 Dodge (F6) Bright Green ?
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: LAD 524] #1693115
11/09/14 02:59 PM
11/09/14 02:59 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
1969 Plymouth # 99 "spring? green metallic"
-- PPG paint code # 44032
1969 Dodge # F6 "bright green metallic"
-- PPG paint code # 2103
Spring Green was a mid year release and was coded 99, 97 or 97E depending on plant and time of year. Any non standard color, that is a color that was not specifically released for that particular make and model or cars that required special painting schemes, like a cop car, will code 99 (1969 code number).
There were some colors that received special coding such as Spring Green. Early on, it appears Spring Green was coded 99. All three plants used 99, 97 or 97E depending on the plant or time of year. Bahama Yellow coded 99 early in the year then later it codes 96. LA tended to stick with the 99 code while Lynch rd plants and ST Louis used 97 or 96 for Green and Yellow/Butterscotch.
Controversy The Fact: Code F6, Bright Green Metallic for Dodge A- and B-Bodies was first mentioned in TSB D69-23-9, dated November 27, 1968. Some sources claimed that Code 97 Rallye Green is also F6 Bright Green Metallic, but the PPG/Ditzler paint numbers are different: 2103 (F6-Bright Green Metallic) and 44032 (97-Rallye Green). The numbers from Ditzler prove that Rallye Green and Bright Green Metallic were different. Additionally, a Chrysler-issued bulletin dated January 22, 1969, listed Ditzler #43898-Rallye Green for '69 Plymouth B-Bodies (Code 99). This is the same number as the catalogued '68 Chevrolet color of Rallye Green Metallic!
As it turns out, through 1968 Ditzler used a five-digit number to identify paint colors. Typically, Ditzler used the numeral "4" as a prefix for green hues. Beginning in 1969, Ditzler went to a four-digit numbering system; however, some five-digit catalog numbers were carried over. The catalog number "2103"-for F6 Bright Green Metallic-was issued during the '69 model year-and no sooner-for '69 Dodge A- and B-Bodies. The code "44032"-Code 97 Rallye Green-was the highest five digit number Ditzler issued for passenger car applications. It was assigned to give Chrysler a specific factory application number in the Ditzler paint books. Ditzler code "43898" is currently cataloged for '68-'69 Chevrolets only.
The actual formula used to create Rallye Green for Plymouth in 1969 was the same formula used for the 1968 Chevrolet-Rallye Green Metallic.
This was not the only time a Chrysler product wore General Motors paint-the '70 Chrysler 300-Hurst's Sauterne Gold Iridescent accents were taken from the '70 Cadillac palette.
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: LAD 524] #1693116
11/09/14 04:36 PM
11/09/14 04:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
After researching the color, looking at original cars and sampling various F6 formulas from various sources/mfg, for my Daytona project, I found (IMHO) that Dupont's Chroma Preimer BC/CC offered the "effect" I thought F6 should have, that being the ability to change color/shade depending on the angle viewed, lighting, shadow, etc
Mike
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: DAYCLONA] #1693117
11/09/14 04:38 PM
11/09/14 04:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
the color can be "dark" depending on the angle of viewing and light, same location, different light/angle
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: DAYCLONA] #1693118
11/09/14 04:40 PM
11/09/14 04:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
again same location, different angle/lighting, nice color transition, light to dark, front to rear
Mike
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: DAYCLONA] #1693119
11/09/14 04:59 PM
11/09/14 04:59 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
outdoor shot
Color shade of F6 will also depend on your primer/base shade/value, I shot the DuPont Chroma Premier over a base shade value of 4 (2K Dupont primer)
Re: Correct colour code for 1969 (F6) Dodge Bright Green [Re: DAYCLONA] #1693120
11/09/14 08:23 PM
11/09/14 08:23 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
outdoor shot
Color shade of F6 will also depend on your primer/base shade/value, I sot the DuPont Chroma Premier over a base shade value of 4 (2K Dupont primer)
Love that car Mike!
On my 6bbl Roadrunner, we tinted the primer green to give it more effect.
