2011 Ram 1500 w/Hemi trouble codes(Techs?) #1692926
10/31/14 07:10 PM
10/31/14 07:10 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
OK, have a 2011 Ram w/54K miles. It set a trouble code today, P0016 (Crankshaft position-camshaft positino correlation bank 1 sensor A, and P000B (Exhaust B camshaft position slow response bank 1). Sounds like the beginning of trouble with the variable valve timing feature. Anyone familiar with this? Thanks in advance.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?) [Re: RTDaddy] #1692927
10/31/14 09:04 PM
10/31/14 09:04 PM
Guitar Jones Offline
When is the last time you changed the oil? Did you put the proper weight oil in? Dirty oil or the improper weight will do that.
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?) [Re: Guitar Jones] #1692928
10/31/14 09:26 PM
10/31/14 09:26 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
Oil changed every time the "alarm" goes "ding." Factory spec oil every time. Changed oil about 2000 miles ago. Running Castrol GTX 5W-20,(that's been the weapon of choice since day one of ownership).
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?) [Re: RTDaddy] #1692929
10/31/14 09:57 PM
10/31/14 09:57 PM
Rio Raton
Lenguevo Offline
Wes Hutchinson says goodbye
Lenguevo  Offline
Rio Raton
Sounds like the cam sensor A on bank one may be failing.
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)update [Re: Lenguevo] #1692930
11/02/14 12:14 PM
11/02/14 12:14 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
Well this ain't good. Yesterday afternoon, after about 30 miles in several trips, check engine light goes out on start-up, engine performance back to normal. If this is anything like the electrical/computer monstrosities at work, they just don't "fix themselves."
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)update [Re: RTDaddy] #1692931
11/02/14 02:39 PM
11/02/14 02:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Some times a quick hiccup will turn on the check engine light and after a certain amount of start ups with out the problem reoccurring it will turn it out. So they do kind of fix themselves.
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)update [Re: stumpy] #1692932
11/02/14 02:47 PM
11/02/14 02:47 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
My 2003 hemi ram 1500 (88,000 miles) will do that from time to time. It will be hard to start and then run very rough for a few seconds. Then all is good and the check engine light comes on but after a few more starts it goes off.
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)update [Re: MidPenMopar] #1692933
11/02/14 04:38 PM
11/02/14 04:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Have it scanned. 3 consecutive good trips will turn the light out but there will still be a code and freeze frame data stored in memory. They don't really fix themselves, just because the light is out does NOT mean there isn't a problem
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)update [Re: Dcuda69] #1692934
11/02/14 10:39 PM
11/02/14 10:39 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
There have been some issues with VCT oil control solenoids going bad. There is a screen on the solenoid that will break apart and cause problems. The solenoid is under the intake manifold.
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)update [Re: teflon] #1692935
11/03/14 11:22 AM
11/03/14 11:22 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
At that age and mileage, it still has really good trade in value. But it will soon be past its prime, and the value will plummet. I'd trade it in now, and thus don't worry about all the electronics going haywire. Theres killer deals to be had on 2014 rams now.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
