Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)
[Re: RTDaddy]
#1692927
10/31/14 09:04 PM
10/31/14 09:04 PM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
OK, have a 2011 Ram w/54K miles. It set a trouble code today, P0016 (Crankshaft position-camshaft positino correlation bank 1 sensor A, and P000B (Exhaust B camshaft position slow response bank 1). Sounds like the beginning of trouble with the variable valve timing feature. Anyone familiar with this? Thanks in advance.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
When is the last time you changed the oil? Did you put the proper weight oil in? Dirty oil or the improper weight will do that.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: 2011 Ram 1500 w/Hemi trouble codes(Techs?)update
[Re: stumpy]
#1692932
11/02/14 02:47 PM
11/02/14 02:47 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Some times a quick hiccup will turn on the check engine light and after a certain amount of start ups with out the problem reoccurring it will turn it out. So they do kind of fix themselves.
My 2003 hemi ram 1500 (88,000 miles) will do that from time to time. It will be hard to start and then run very rough for a few seconds. Then all is good and the check engine light comes on but after a few more starts it goes off.
[Re: teflon]
#1692935
11/03/14 11:22 AM
11/03/14 11:22 AM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
At that age and mileage, it still has really good trade in value. But it will soon be past its prime, and the value will plummet. I'd trade it in now, and thus don't worry about all the electronics going haywire. Theres killer deals to be had on 2014 rams now.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
