426 Hemi into a 65 B body shock modification #1692880
10/31/14 03:25 PM
10/31/14 03:25 PM
6T4 Polara Offline OP
Passenger shock tower modification required to use a Hemi engine with valve adjustment access.
Looking for someone in the Metro Detroit area familiar with the modification and able to do it.
Re: 426 Hemi into a 65 B body shock modification [Re: 6T4 Polara] #1692881
10/31/14 08:06 PM
10/31/14 08:06 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I know you have to do it on an 68 A body.
Is it also required on a 65 B body?
I have a 65 Bel II with the inner fender and firewall work done.
That just may be a deal breaker for me if so.
...FAFO...
Re: 426 Hemi into a 65 B body shock modification [Re: skicker] #1692882
10/31/14 08:51 PM
10/31/14 08:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The bump under the shock hole has to be moved away from engine, slice the hole area then flip. You also have to clip the front upper a-arm area, leave a hole there.I'll try to find a pic
Here
Re: 426 Hemi into a 65 B body shock modification *DELETED* [Re: 6T4 Polara] #1692883
10/31/14 10:32 PM
10/31/14 10:32 PM
Chicago Blackhawks
hemicar1971 Online content
hemicar1971  Online Content
Chicago Blackhawks
Post deleted by hemicar1971
Re: 426 Hemi into a 65 B body shock modification [Re: hemicar1971] #1692884
10/31/14 10:38 PM
10/31/14 10:38 PM
SW CO
HemiSportFury Offline
SW CO
I did not invert the shock tower when I put the 528 in my 64 Sport Fury. The valve cover is very close to the shock stud but I have a tie down on the engine to keep it from rocking so it is not a big deal.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: 426 Hemi into a 65 B body shock modification [Re: HemiSportFury] #1692885
10/31/14 10:46 PM
10/31/14 10:46 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
i was able to get the valve cover off of one i built a few years back, and it had the ultra rare mickey thompson k-head cast valve covers, it did not have the inverted shock tower, just don't use the schumacher hemi conversion mounts, unless they have fixed the issues that those have.
Re: 426 Hemi into a 65 B body shock modification [Re: 6T4 Polara] #1692886
10/31/14 11:26 PM
10/31/14 11:26 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Here's a pic of an inverted shock tower mod from Mosher's site.
Previous owner of my 64 belvedere, cut the passenger tower & welded
a flat top on it so I'm gonna leave it that way since its part of its
history.
Re: 426 Hemi into a 65 B body shock modification [Re: Triggerfish] #1692887
10/31/14 11:27 PM
10/31/14 11:27 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
finished & painted..
Re: 426 Hemi into a 65 B body shock modification [Re: Triggerfish] #1692888
11/01/14 12:13 AM
11/01/14 12:13 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Awesome pic's and info
Re: 426 Hemi into a 65 B body shock modification [Re: 6T4 Polara] #1692889
11/01/14 02:59 PM
11/01/14 02:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You gotta remember that engineers are an anal lot, they set clearance standards and won't deviate from them. I've seen a lot of GEN 2 Hemis in early B's with no engine compartment mods.
Re: 426 Hemi into a 65 B body shock modification [Re: cudaman1969] #1692890
11/01/14 06:21 PM
11/01/14 06:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Here are the pids
Re: 426 Hemi into a 65 B body shock modification [Re: cudaman1969] #1692891
11/01/14 09:21 PM
11/01/14 09:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Factory pic from 1963.
Doug
Re: 426 Hemi into a 65 B body shock modification [Re: dvw] #1692892
11/01/14 09:22 PM
11/01/14 09:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Engine pic
Re: 426 Hemi into a 65 B body shock modification [Re: cudaman1969] #1692893
11/01/14 10:26 PM
11/01/14 10:26 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Thanks for the excellent photos. Here's how the orig owner modded
my shock tower. Yours looks MUCH nicer!!
65 Dodge Cornett 440 [Re: Triggerfish] #1692894
11/02/14 04:24 PM
11/02/14 04:24 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
Here's one Modified in a 65 Dodge 440 Cornett
Re: 65 Dodge Cornett 440 [Re: Bishop] #1692895
11/03/14 09:34 AM
11/03/14 09:34 AM
Thanks for the responses.
I have forwarded the information.
