rear bolt on tie down brackets #1690864
10/26/14 06:32 PM
10/26/14 06:32 PM
mo
ALKYW5DART Offline OP
mo
Looking for the guys email or screen name on moparts that was selling the rear bolt on tie down brackets they bolted inbetween rear leaf springs and rear end they wear cnc cut and only 1/8 or 1/4 inch thick. I think he lived in missouri like around st louis thanks guys
Re: rear bolt on tie down brackets [Re: ALKYW5DART] #1690865
10/26/14 07:35 PM
10/26/14 07:35 PM
AndyF Online content
AndyF  Online Content
I make a chassis tie down bracket. It usually get attached at the bumper bracket.
Re: rear bolt on tie down brackets [Re: AndyF] #1690866
10/26/14 10:13 PM
10/26/14 10:13 PM
mo
mo
That would work great on the front but the ones im lookin for wear for the rear and they wear posted here on moparts
Re: rear bolt on tie down brackets [Re: ALKYW5DART] #1690867
10/27/14 12:10 AM
10/27/14 12:10 AM
Maryland
gofastboater Offline
Maryland
1st off, NEVER tie down to the body. ALWAYS to the suspension. You CANNOT get the straps tight enough to keep the body from stretching your straps. Sooner or later they will snap. Find a point on the rear itself. Usually near the shock plate. I usually use the u-bolt and attach a link or 2 of chain. On the front find a spot close to the lower balljoint. I have used the sway bar link hole. I have also bolted a small piece of chain to the lower control arm. By attaching to the suspension the tires cannot move. The spring in the body will allow the straps to go loose on compression and on decompression that's when the snap. I have seen way too many straps snapped and the car moves and gets damaged. Hooked to the suspension there is no compression or decompression therefore they can't break. I have been towing cars and heavy equipment for close to 45 years and have NEVER had any damage using this method. As an example, look at any new car carriers. They all use wheel style straps. No more chains to the frame. They have been using this method for many many years. They found out that by not getting the chains tight enough the hooks were pulling out of the frame, by the bodies compressing and decompressing the suspension, damaging them. I hope this helps someone to not damage their vehicle. Good luck.
Re: rear bolt on tie down brackets [Re: ALKYW5DART] #1690868
10/27/14 01:19 AM
10/27/14 01:19 AM
I have these on my Coronet but I don't sell them as a product. They are fairly easy to make.
Re: rear bolt on tie down brackets [Re: ALKYW5DART] #1690869
10/27/14 02:50 AM
10/27/14 02:50 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I believe you're talking about Blues_Cuda / Scott Litzau.
https://board.moparts.org/ubbthreads/show...hat=showmembers
Re: rear bolt on tie down brackets [Re: gofastboater] #1690870
10/27/14 09:39 AM
10/27/14 09:39 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Now top shock manufacturers say strap the body to stop body movement during towing. The straps I run are rated for the whole weight of the load per single strap and are inspected regularly.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: rear bolt on tie down brackets [Re: gofastboater] #1690871
10/27/14 10:06 AM
10/27/14 10:06 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I believe what the OP was asking for is for the suspension? It bolts to the u bolts and that's part of the rear end.
IMO I would never add weight to my race car just to tie it down. Plus the extra weight is going to change the shocks settings too.
I would just use axle straps to it tie down.
Here a post where I was preaching on how to tie down a car. See if you agree with me? web page
Re: rear bolt on tie down brackets [Re: Challenger 1] #1690872
10/27/14 10:28 AM
10/27/14 10:28 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
As I posted before,
His contact info is in the link.
Scott and his dad Rich started making the tie down plates that are sandwiched between the leaf springs and the shock plates earlier this year (about May).
He posted here on Moparts about selling them but I can't find any of the posts on them.
I thought about getting a set but didn't want to take the Caltrac's loose on my car.
What I thought about doing on my car is adding a small metal loop on the front of the lower shock stud.
Since I have Caltracs (rather than the stock shock plates) the shock mount stud is a bolt on instead of being welded on.
Re: rear bolt on tie down brackets [Re: SNK-EYZ] #1690873
10/27/14 06:21 PM
10/27/14 06:21 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
Been using Rich's tie down brackets most of the season with no issues whatsoever. Very happy with them. Also, they fit perfectly with caltracs & mono's. Can't remember his screen name.
Re: rear bolt on tie down brackets [Re: cb1289] #1690874
10/31/14 10:16 AM
10/31/14 10:16 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Sorry I missed this post. I don't get on Moparts as often as I used to. Here's a pic of our tie down brackets. Dad met up with Gary (The OP of this thread.) earlier this week.
Re: rear bolt on tie down brackets [Re: Blues_Cuda] #1690875
10/31/14 04:02 PM
10/31/14 04:02 PM
Canada
onig Offline
onig  Offline
Canada
What is the price of these brackets?
69 Dart
Re: rear bolt on tie down brackets [Re: onig] #1690876
11/01/14 09:57 AM
11/01/14 09:57 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I'll send you a PM.
Re: rear bolt on tie down brackets [Re: Blues_Cuda] #1690877
11/01/14 10:06 AM
11/01/14 10:06 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I personally would rather tie down from the chassis. just to help keep the shocks from working so much especially if you don't use a shock saver. you can literately wear out a set of race shocks towing your car.
Re: rear bolt on tie down brackets [Re: Blues_Cuda] #1690878
11/01/14 03:34 PM
11/01/14 03:34 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I'll send you a PM.
please send me a pm too. thanks mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
