Re: Extra holes on A12 LH inner fender??
[Re: 69hemibeep]
#1690344
10/25/14 01:42 PM
10/25/14 01:42 PM
Posts: 449 DFW
68RRFlyer
DFW
Stan, Notice that they are around the circumference of the spot welds for the inner fender shock tower brace on the underside. The holes don't go all the way through, so I'm not sure exactly what they were used for. Possibly something for alignment of the panels during assembly?? Leave them there. They are stock for all B-Body cars that I'm aware of. I checked my A12 Bee to verify they are there (thanks for the heads up James!!! ) and they are. I have also seen them on several 69 Chargers I've owned. The other three "dimples" I believe are for A/C line bracket hold downs. Cheers Dave
[Re: JohnRR]
#1690347
10/26/14 11:33 AM
10/26/14 11:33 AM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
all of mine have them. I agree they are for the CC servo bkt. a buddy had a 68 GTX that had cruise and the bracket mounted right there!
HEMI,S ARE FOREVER!!!
[Re: 1969 HEMI R-T]
#1690348
10/26/14 03:57 PM
10/26/14 03:57 PM
Posts: 17,514 Las Vegas, NV
6bblgt
Las Vegas, NV
They are "pilot holes" to be drilled for the cruise control mounting bracket (if so equipped), here's my first MOPAR - a '68 383 4bbl Charger. There are many spot welds in that area to attach inner fender to the upper shock tower and related inner fender support.
[Re: 6bblgt]
#1690349
10/26/14 04:18 PM
10/26/14 04:18 PM
Posts: 1,805 ky hills
thehemikid
ky hills
What is the distance from hole to hole? What size bolts/screws are used there on the cruise control? My 70RR has 2 holes in that spot weld "arc" but are bigger diameter holes than pictured above.
[Re: thehemikid]
#1690352
11/23/14 09:51 AM
11/23/14 09:51 AM
Posts: 1,672 Virginia
HemiStan
Virginia
Jeff,
Sorry for the delay in getting this info. Yes, the holes are 3 and 3/16" center to center.
Stan
[Re: HemiStan]
#1690353
11/23/14 12:28 PM
11/23/14 12:28 PM
thehemikid
ky hills
Jeff,
Stan
That's ok Stan...I know it takes a while to count all those little lines. ...and Thanks!
I appears to me, someone had a cruise control on this 4spd car back in the 70's.
I had always wondered what someone had mounted there. I tried an MSD but it didn't match any holes. But for some reason, I guess being a 4spd, ...never even thought about cruise until I read this thread.
I've been try'n to get a hold of one of the previous owner's who bought it in about 78 to see if he remembers it being on it when he got it.
...and it's got me 'n ...it'd be nice to have.
