Re: 360 heads redone, valve stem heights are different?
[Re: cudabitten]
#1688828
10/21/14 11:56 PM
10/21/14 11:56 PM
Posts: 5,903 Florida
Locomotion
Ideally, all valves should be the same height. But variances are usually from inconsistent amounts cut when doing the valve job on the seat angles as well as the valve angles. It's not good to "sink" the valves, but sometimes if the seats are all beat up, it is necessary. I don't really know what an "acceptable range" would be. I guess it depends on the person.
[Re: madscientist]
#1688832
10/22/14 09:53 AM
10/22/14 09:53 AM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
Is it possible to "fix" this with lash caps? I think I only have one or two rockers that are "really" loose. Some others are loose on the shaft where they can slide side to side.
What rockers do you have. I don't know how you miss by .020-.025 short when doing a valve job. If you sink the valve, you lengthen the stem height.
Exactly. Only thing I can think of is that either he or someone previously re-did the seats on the other valves and now they are high. Or someone replaced a couple valves in the past? I read that valves stems stretch, called "necking", buy I don't think they could stretch that far. The rockers are LA style, non-adjustable. Motor is a 78.
[Re: cudabitten]
#1688833
10/22/14 10:04 AM
10/22/14 10:04 AM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
There is a spec for the height from the spring seat to the tip of the valve for a factory iron head and stock length valves. I ran into this years ago with a 440 I built, some of the valves were sank enough that it had a pop caused by the valves being held open. I had to explain to them this wasn't a abc . P.S. I'd check the spring installed height too.
[Re: cudabitten]
#1688837
10/22/14 11:39 AM
10/22/14 11:39 AM
Posts: 4,219 New York
polyspheric
New York
The shop screwed up. Unless there's a good reason (such as a big difference in lift intake vs. exhaust) the stems should be the same height. "Different sizes" = he has no idea what he's talking about. The good news (if any?): the difference is too small to fix with lash caps, which are .050" thick minimum. If you want to take the heads apart you can shorten the taller stems but it's difficult work. Larger question: how far away is the geo with the stems now?
Boffin Emeritus
[Re: cudabitten]
#1688839
10/22/14 12:34 PM
10/22/14 12:34 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I fired up my 360 after having the heads redone, ( 5 angle grind, new springs installed-comp 901-16, valves refinished, .020 shaved). I was breaking in a new cam, and had at least one rocker knocking noise. I removed the valve cover and found that the valve stems are all a bit different heights on both heads. The two in the front are .025 and .020 lower than the rest. A few others are about .008 lower. I called the shop that did the work and the guy said that mopar exhaust and intake valves are different sizes. What is the right answer? The guy told me before I bring the heads back to him to check the lifter to make sure it is not collapsed. I did that and they are all fine. I'm not sure I want this guy to do these again. What should I do? Do I need to check spring height as well as valve stem height? What about the geometry in the combustion chamber? If he keeps grinding the seats, isnt that changing?
2 words ...
ADJUSTABLE PUSHRODS ...
I have done this on the last 2 motors I've done for friends that insisted on using stamped rockers so I was able to set the lifter preload to manufacturer of the lifters spec.
Sounds like you have a pretty stockish build so your lifters should have been preload enough that you wouldn't have had an issue with too litle preload, especially on the ones you say are off by .008.
[Re: cudabitten]
#1688843
10/22/14 05:44 PM
10/22/14 05:44 PM
Posts: 26,530 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When I was taught to do valve jobs it was accepted practice to adjust the valve stem length so that all the valve stem tips were at the same height....there is an attachment on the valve grinder for grinding the valve stem ends. Some FSM's show a tool that is used to measure the height of the installed valve stem tip above the spring seat.
A good machinist will deliver heads that have the correct valve stem height and equal heights so that a straight edge laid across the stem tips will show no daylight.
[Re: John_Kunkel]
#1688845
10/22/14 07:30 PM
10/22/14 07:30 PM
justinp61
W. Kentucky
Exactly!
[Re: John_Kunkel]
#1688847
10/22/14 11:11 PM
10/22/14 11:11 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
This is just what I was taught in high school auto shop and my brothers valve grinder has the tool to grind the valve stem ends. Ron
[Re: dvw]
#1688848
10/22/14 11:25 PM
10/22/14 11:25 PM
cudabitten
eastern, pa.
Ok, Thanks Everyone. I did a little more research on this...I've been building this car for seven years and just fired her up on Friday, so I am on the home stretch with this project. Anyway, The Spec on the valve spring height is, for a 1978 360 2 bbl (I converted to a 4bbl which has a tighter spec) is 1 5/8 to 1 11/16 which converts to 1 40/64 to 1 44/64 which is easy to work with since my calipers are in 64ths. So here is what I measured just for the record. I could not get to all off the spring seats on the passenger side, so here is the drivers side... from front to back: E 1 38/64, I 1 43/64, I 1 43/64, E 1 37/64, E 1 37/64, I 1 43/64, I 1 42/64, E 1 37/64. So all of the E's (Exhaust valves) are out of spec. All of the I's (Intake Valves) are right on. So I dont think I can use the lash caps as was stated, they are way too thick. And as was stated, NO I do not want the same guy grinding on these anymore. As long as I dont have any valves not closing or not opening all the way, I am cool with going with something adjustable. Or maybe using some longer push rods on the Exhaust valves. Can you please look at my numbers and tell me if the valves will be opening enough and closing enough? And will longer pushrods on the exhaust valves be a solution, or adjustable rockers? Thank you for all this help.
[Re: cudabitten]
#1688849
10/23/14 10:10 PM
10/23/14 10:10 PM
Posts: 4,457 Washington
madscientist
Washington
Be careful here. Stem height and spring height are NOT the same thing.
The best solution is to use pushrods that are longer on the valves that have the STEM HEIGHT too short. You only need to have .040-.060 preload on the lifter. If you have that you are golden.
