Re: da shocks on cal trac suspension [Re: hemi-itis] #1688735
10/23/14 09:52 PM
10/23/14 09:52 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Has anyone had good luck with the Vikings shocks yet? The two that I have spoken too haven't had any success.
Please elaborate
Car are not working on the nitrous, not hooking.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: da shocks on cal trac suspension [Re: 1967dartgt] #1688736
10/23/14 10:10 PM
10/23/14 10:10 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Please elaborate
Have they tried to tune them??
I went for the aggressive valving on the rears,have not had the time to fine tune them as of yet
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: da shocks on cal trac suspension [Re: hemi-itis] #1688737
10/23/14 10:16 PM
10/23/14 10:16 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes I have pm'd them on what settings I would try. They have tried many settings no luck as of yet.
Re: da shocks on cal trac suspension [Re: hemi-itis] #1688738
10/23/14 10:22 PM
10/23/14 10:22 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Please elaborate
Where are you buying the Afco's or the Viking shocks from and pricing? Since I changed to a 1050 dom. carb I am having severe traction problems that I did not have when I was running the 950 carb. I am using the Caltrac front shocks now and I think I need to go to double adjustable front shocks.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: da shocks on cal trac suspension [Re: D-50] #1688739
10/23/14 10:54 PM
10/23/14 10:54 PM
hemi-itis Offline
hemi-itis  Offline
Bought the Vi-kings from Chris at Vi-king. Shocks were like $700 plus $100 for the aggressive valving on the rears for a total of $800. Have been concentrating on fine tuning the carbs and and I think I found the sweet spot for timing.
Have not installed the fronts yet,another week or 2
Re: da shocks on cal trac suspension [Re: D-50] #1688740
10/23/14 10:56 PM
10/23/14 10:56 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Afco has a lot of vendors, Viking Performance you can contact directly.
What's your rear shock? Could be the culprit
Re: da shocks on cal trac suspension [Re: SpareParts] #1688741
10/23/14 11:14 PM
10/23/14 11:14 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Rancho with 9 adjustments set on 9. I think the front is coming up too fast. It will pull the front tires a foot or so then blow the tires off. When I had the 950 on it it would carry the front tires 50 ft. and when the front came down it would unload the rear tires. That is why I think I need double adjustable.
The pic is when it had the 950 and hooked then came back down after a carrying the wheels a ways. Now it hooks for only a few feet.
Re: da shocks on cal trac suspension [Re: D-50] #1688742
10/23/14 11:42 PM
10/23/14 11:42 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
said it before .
slow down the front.
Re: da shocks on cal trac suspension [Re: a493demon] #1688743
10/24/14 12:01 AM
10/24/14 12:01 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
said it before .
That is why I think I need double adjustable front shocks, am I thinking correctly?
Re: da shocks on cal trac suspension [Re: D-50] #1688744
10/24/14 12:04 AM
10/24/14 12:04 AM
a493demon Offline
a493demon  Offline
yes but prob. wouldn't hurt all the way around.
Re: da shocks on cal trac suspension [Re: D-50] #1688745
10/24/14 12:22 AM
10/24/14 12:22 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You need rear shocks, your rear shock is not keeping your tire planted. Your front is off the ground already and cant have a impact at this point. Valveing in shocks are not tight enough and your radial is bouncing and unloading. You will probably find once you keep rear planted you will need to limit front end travel or get a da shock.
Re: da shocks on cal trac suspension [Re: 1967dartgt] #1688746
10/24/14 12:56 AM
10/24/14 12:56 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Where is the place to get the best price on the Afco shocks?
Re: da shocks on cal trac suspension [Re: D-50] #1688747
10/24/14 01:16 AM
10/24/14 01:16 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mark Menscer 910-624-1119 for custom ones, you can get them from summit also.
Re: da shocks on cal trac suspension [Re: 1967dartgt] #1688748
10/24/14 02:32 AM
10/24/14 02:32 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
We had tried Afcos on the Buick before and I wasn't impressed, so I put Santhuffs all the way around on it and they are really good shocks. Mark Menser came to us last year and wanted us to try some of his on the rear. He uses Afcos that he revalves to his specs. Told him my experience with the Afcos and he said that if they didn't work better than the Santhuffs on the rear, he would buy them back. He said the Santhuff was a GREAT shock, but he thought his were better for small tires and high horsepower. So we gave him a shot. The last two races on radials we have been (3) 1.06s (2) 1.08s (1) 1.07 (1) 1.09 and (2) 1.10s.......guess they work
Monte
Re: da shocks on cal trac suspension [Re: Monte_Smith] #1688749
10/24/14 04:48 PM
10/24/14 04:48 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Sorry for the hijack, could someone PM me an Email for Mark Menscer?
TIA
Re: da shocks on cal trac suspension [Re: Monte_Smith] #1688750
10/25/14 07:55 AM
10/25/14 07:55 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Monte
Well that's reassuring , think I may see my rears to mark.
Mopar Performance
