Re: Rocker arm shaft spacers or springs... [Re: hemi-itis] #1688510
10/24/14 04:34 PM
10/24/14 04:34 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I had an original set of isky's and they had some HEAVY springs , they work to keep the rocker from moving off to the side , it can happen , but add a lot of friction. The later isky's and cranes ... and the hemis ... have much lighter springs, but I can see the rocker deflecting sideways a little if the pushrod is not pushing straight up, this is why the $$$ rockers use spacers instead of springs , especially if you have offset rockers.
I'd like to try a shaft mounted locking collar with ductile rockers, they make them for the Hemi
I see them and now I have to say ... A complete waste of money and not necessary ... after reading the replies above.
Re: Rocker arm shaft spacers or springs... [Re: Stanton] #1688511
10/24/14 04:52 PM
10/24/14 04:52 PM
And if installed properly, there is minimum friction using a spring - you need to shim between the spring and rocker and should always shim between the rocker and hold-down.
Some have mentioned the rocker moving sideways enough that the rocker tip moves off the valvestem. I'm not saying it can't happen BUT what heads have that wide of a pushrod hole that will allow the pushrod that much movement? Stockers don't and neither do my Indy EZ's. Just sayin'!
Take a look at the Mopar stock "906" heads, lots of room That rocker arm and pushrod was on the intake on the #6 cylinder
Re: Rocker arm shaft spacers or springs... [Re: Cab_Burge] #1688512
10/24/14 09:12 PM
10/24/14 09:12 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
HELLO I WORKED ON MY ROCKER ARMS TODAY AND I PUT A 15000 SHIM ON EA OUTER SIDE .CHECKS TO BE OK WITH MY EZ HEADS .THE PUSH RODS KEEPS THEM WILL CENTER . HAVE A GOOD MOPAR DAY !!
Re: Rocker arm shaft spacers or springs... [Re: JohnRR] #1688513
10/24/14 09:26 PM
10/24/14 09:26 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
At least say they lokk "cool"
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Rocker arm shaft spacers or springs... [Re: hemi-itis] #1688514
10/25/14 04:36 PM
10/25/14 04:36 PM
JohnRR Offline
JohnRR  Offline
At least say they look "cool"
Re: Rocker arm shaft spacers or springs... [Re: JohnRR] #1688515
10/25/14 06:50 PM
10/25/14 06:50 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I sell the shaft clamp sets. With or without spring washers. In anodized red or plain aluminum.
TR Waters
Re: Rocker arm shaft spacers or springs... [Re: TrWaters] #1688516
10/25/14 07:26 PM
10/25/14 07:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Wish I could say I thaught of the collar deal .............Would make the shaft assembly easier to work w/and the final side by side adjustments could be made w/the holds downs only instead of shufflin everything around.
Re: Rocker arm shaft spacers or springs... [Re: JohnRR] #1688517
10/26/14 12:50 AM
10/26/14 12:50 AM
hemi-itis Offline
hemi-itis  Offline
Thanks John
