Re: Rocker arm shaft spacers or springs...
[Re: hemi-itis]
#1688510
10/24/14 04:34 PM
10/24/14 04:34 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I had an original set of isky's and they had some HEAVY springs , they work to keep the rocker from moving off to the side , it can happen , but add a lot of friction. The later isky's and cranes ... and the hemis ... have much lighter springs, but I can see the rocker deflecting sideways a little if the pushrod is not pushing straight up, this is why the $$$ rockers use spacers instead of springs , especially if you have offset rockers.
I'd like to try a shaft mounted locking collar with ductile rockers, they make them for the Hemi
I see them and now I have to say ... A complete waste of money and not necessary ... after reading the replies above.
[Re: JohnRR]
#1688513
10/24/14 09:26 PM
10/24/14 09:26 PM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
At least say they lokk "cool"
[Re: JohnRR]
#1688515
10/25/14 06:50 PM
10/25/14 06:50 PM
Posts: 2,129 Vermont
TrWaters
Vermont
I sell the shaft clamp sets. With or without spring washers. In anodized red or plain aluminum.
TR Waters
