Re: CalTracs/Drag Radials and a 4 Speed [Re: StealthWedge67] #1688242
10/21/14 10:39 AM
10/21/14 10:39 AM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
From watching the video it looks like there is not enough travel in the front suspension... Calvert will tell you that you need at least 5" of travel in the front. Tighten the rear shocks and getting some travel in the front will surely help a bunch.
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: CalTracs/Drag Radials and a 4 Speed [Re: QTR MILR] #1688243
10/21/14 12:15 PM
10/21/14 12:15 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
It has right at 5" of travel. It looks like it doesn't fully extend when it's spinning but when it's hooked up and moving it's extended all the way. He does have a few options the next time he goes to test and tune.
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688244
10/21/14 12:31 PM
10/21/14 12:31 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Heres' the video
http://youtu.be/GX91HLOeFU0
Wow good looking dart!! That is what my car looked like when I got it. Just had a vinyl top. Good luck with it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: CalTracs/Drag Radials and a 4 Speed [Re: 1967dartgt] #1688245
10/21/14 12:39 PM
10/21/14 12:39 PM
Tucson, Arizona
Tucson, Arizona
Thanks Brad. It's morphed quite a bit. The next stage should be good. matt
BTW: Anybody have a quarter panel "T"?
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688246
10/21/14 01:42 PM
10/21/14 01:42 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
If I can find it. I took them off my car. I will look and let you know
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688247
10/21/14 06:02 PM
10/21/14 06:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wow Matt! been a long time since I've see the ole cream puff! looks good! Miss those pretty views at SIR.
Re: CalTracs/Drag Radials and a 4 Speed [Re: J_BODY] #1688248
10/21/14 06:35 PM
10/21/14 06:35 PM
Tucson, Arizona
Tucson, Arizona
Jay,
It looks a little different than @ 2007 Pinks Allout.
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: 6PKRTSE] #1688249
10/21/14 07:49 PM
10/21/14 07:49 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
Yeah, Drag Radials & sticks do not go together all that well. Radials like to stay planted & are not forgiving like a slick. You can tune it eventually to get it to some what work.
A clutch slipper can really help make drag radials compatible with a manual trans. Just an extra 1/10th of a second of clutch slip can reduce the drivetrain's shock from clutch engagement by appx 50%.
Here's a link to a very effective clutch slip controller that you can put together for under $50... DIY clutch slipper
Re: CalTracs/Drag Radials and a 4 Speed [Re: weedburner] #1688250
10/22/14 04:22 AM
10/22/14 04:22 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
FYI you will need a shorter cylinder if you want to hide it under the dash of an a or b body. Works good on the street also! I suggest calling M&H for drag radials on a stick car.
Re: CalTracs/Drag Radials and a 4 Speed [Re: Jeremiah] #1688251
10/22/14 01:46 PM
10/22/14 01:46 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
The cylinder can be mounted along the side of the pedal if it needs to be completely hidden. It could also be hidden in plain sight with a different knob for easier access, maybe as an e-brake release or manual choke?
