Page 2 of 4 1 2 3 4
Re: Bored with 660hp.... [Re: B3422W5] #1687881
10/19/14 10:17 PM
10/19/14 10:17 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nope, not at 124 MPH, there is some HP missing. Needs a bigger carb and jetted accordingly. You might be surprised how big of jet I have in an 1150 dominator to give it what it needs.
First calculation I assumed the 3220 lbs was race weight. It should dip in the nines if everything is playing nice.
Little more weight...
Your ET / MPH computed from your vehicle weight of 3480 pounds and HP of 660 is 10.14 seconds and MPH of 133.30 MPH.
Give it fuel and air and let it eat.
Re: Bored with 660hp.... [Re: Dragula] #1687882
10/19/14 11:46 PM
10/19/14 11:46 PM
It lays over on the top end after shifting to 3rd, and even sometimes at the top of 2nd....
So at a race weight of 3480lbs, and a best trap speed of 124mph, what do you guys calculate? 660hp seems pretty close to me.
I know last year when it ran 10.84 there was another .10 in it of I sealed the carb to the hood.
I keep wondering about the MSD box though....
You say you almost have the motor out of the car. leak it down and then concentrate on fixing the fuel delivery problems My 518 C.I. 400 stroker made 727 HP on the dyno the last time I tested it, that motor ran 9.993 at 134.6 MPH at 3450 lbs with me in the car on Oregon 91 octane non ethanol pump swill through the full exhaust exiting at the rear bumper with the air cleaner on I di have a bunch of fuel delivery gremlins when I built the car, I used a BG 500 fuel filter(10 micron) between the pump and the gas tank Once I bought and used a LM1 wide ban I was able to idemtify it going lean at the hit of the throttle, it would still run mid tens at 127.= MPH It ran better when I fixed the fuel system, low tens at 128 + MPH Fix the obviuos(SP?) first after fixing the fuel delivery I hopped it up by using bigger and better heads, it went faster again
Re: Bored with 660hp.... [Re: Bigcube] #1687883
10/20/14 12:42 AM
10/20/14 12:42 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Well I know the carb is fine. That is the carb off the Duster and its been in the 9.70's already with a quickest pass of 6.14 in the 1/8th.
I am half tempted to put this engine on a dyno and see WTH is wrong with it. I will check the cam first as I had trouble with #8 intake most of the summer until I replaced the adjuster...Since then it has been good.
Re: Bored with 660hp.... [Re: Dragula] #1687884
10/20/14 12:45 AM
10/20/14 12:45 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Is it carb or injected? What's the combo run down?
Its carburated currently. It was injected previously and I have the injection unit but sold the ecu....
So currently it is:
484 cubes with a 4.15 crank and 4.31 JE pistons
11.5:1 compression
mild .600 lift mechanical chevy cam
426-1 Indy heads flowing 400cfm
1000cfm carb and port matched intake
Car is 4.10 gears
31" tires
4500 stall
car weighs 3220lbs
I had 4.56's in it last year with a 5000 stall, but hated all the rpm on the street.
It went 10.84 last year with the 4.56s and only 10.93 this year so far. Car is super drivable, so I have that covered...
Sorted 2-circuit Dominator territory in my opinion.
Re: Bored with 660hp.... [Re: Dragula] #1687885
10/20/14 12:51 AM
10/20/14 12:51 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
This is where a engine dyno is a invaluable tool and I’ll bet I done this a dozen times for customers. If you are taking the engine out, take it, your ignition system, air cleaner and exhaust headers to an engine dyno. In a short period of time they will either have the tune up figured out or tell you the problem is back at the car. I.E fuel delivery, exhaust sytem. Or you could keep changing things until you fine it. Fuel, ignition, voltage, cam etc etc.
Joe
edit: I was typing up my reply before i seen your last post.
Without Data, you’re just another guy with an opinion.
Re: Bored with 660hp.... [Re: sr4440] #1687886
10/20/14 08:09 AM
10/20/14 08:09 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Randy I'd definitely get it on the dyno and get some answers. I got bored with 700 a few years ago. 853 hasn't bored me yet, the chassis isn't up the task yet and trys to kill me on a regular basis. Dave
Re: Bored with 660hp.... [Re: quickd100] #1687887
10/20/14 01:05 PM
10/20/14 01:05 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Before you finish pulling it out find what's called a Tuner and put it on the Chassis dyno and let them get it right for you and if nothing else it will be Tuned right and you can see what you have or don't have.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Bored with 660hp.... [Re: Dragula] #1687888
10/20/14 01:12 PM
10/20/14 01:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that doesn't sound like an egine problem. It should run WAY better that 10.80's... That's a pretty big and expensive mill. What is the fuel system? What/how does it run before it lays down?
Coming soon!!!!
Re: Bored with 660hp.... [Re: Dragula] #1687889
10/20/14 03:13 PM
10/20/14 03:13 PM
dogdays Offline
dogdays  Offline
I'd be disappointed too if my 484 Hemi was only putting out 520 flywheel horsepower. That's what your numbers say when put into any number of calculators.
The 660hp is a myth.
And, what can you expect with a chevy cam?
But really, it's not the engine's fault, you have a tuning problem hiding around 100hp.
R.
Re: Bored with 660hp.... [Re: dogdays] #1687890
10/20/14 04:34 PM
10/20/14 04:34 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Post a picture of your last ET slip from the track. HP is seen as MPH on the ET slip. If you were running 134 at the same ET, it would show you the problem was with getting the car off the line, etc... Just curious if you possibly have an RPM limiter on the car that's engaging at the top end, limiting your RPM. Just a thought. TD
Re: Bored with 660hp.... [Re: Dragula] #1687891
10/20/14 08:22 PM
10/20/14 08:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
OK, I don't doubt the carb is fine, but Hows the fuel pressure, what system pump are you using. Even good carbs wont work without fuel.
Laying down in third and sometimes at the top of second is a classic example of a fuel issue. But not always a guarantee. Fuel would be my bet Until I hear of your Fuel set up.
Re: Bored with 660hp.... [Re: Tommy D] #1687892
10/20/14 08:22 PM
10/20/14 08:22 PM
Dragula Offline OP
Dragula  Offline OP
It went 124mph at 10.84...
Re: Bored with 660hp.... [Re: Dragula] #1687893
10/20/14 09:41 PM
10/20/14 09:41 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
The Wallace Racing calculator says 124 mph at 3480 lbs is 531 flywheel horsepower. ET is 540 hp
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Bored with 660hp.... [Re: D-50] #1687894
10/20/14 09:51 PM
10/20/14 09:51 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Both ET AND MPH are way way down. Just a high side ignition miss wont bring back that much missing ET. ET is all made up in the eigth mile. Who specd the cam, and what are all the numbers on the head CFM, just not the "big" number?
RIP Monte Smith
Re: Bored with 660hp.... [Re: CompWedgeEngines] #1687895
10/20/14 10:36 PM
10/20/14 10:36 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I don't understand Why your asking about the cam??
Drag, states that its laying down in third and sometimes in second.
Until That's , straightened out, you can forget about the cam numbers for now.
EDIT, also I haven't seen a 60 ft. number yet. That would be another good indicator of what may be going on. If its soft too, then yes, something other then fuel delivery will be the problem.
Re: Bored with 660hp.... [Re: CompWedgeEngines] #1687896
10/20/14 10:51 PM
10/20/14 10:51 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
In my case a MSD " high speed miss" in top half of second, and high gear, did knock out a ton of steam. From 10.50's when it would " act up" to. 9.90's when it ran normally.
Ultimately it started doing it every pass, and I finally swapped it out and fixed the problem(6al box).
If the OP is dealing with the same issue, the ET swing would put his car near where it should run.
My issue was extremely similar..... Box is pretty easy to swap to rule out. Especially if it happens to be an older 6al
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Bored with 660hp.... [Re: Sport440] #1687897
10/20/14 11:39 PM
10/20/14 11:39 PM
Syracuse,NY
Syracuse,NY
How they selected the cam, why they selected THAT cam, and how they mated it with the heads, will provide some more information about the total package.I have seen cams kill combinations. I dont think that is the " only" thing wrong here, but I am curious as to a few things. Ive certainly seen MSDs fail, thats for sure.I normally see them just die, or simply misfire. Not really " lay over" First time for everything, thats for sure.
RIP Monte Smith
Re: Bored with 660hp.... [Re: CompWedgeEngines] #1687898
10/21/14 12:44 AM
10/21/14 12:44 AM
Dragula Offline OP
Dragula  Offline OP
Cam Card....Was not spec'd by me.....And remember I have rockers with higher ratio's
Re: Bored with 660hp.... [Re: Dragula] #1687899
10/21/14 09:21 AM
10/21/14 09:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
So w/ the 1.6's you have 622/627 lift. I run a similar 588 comp solid roller. Mine pulls until about 6400, I'm guessing with the hemi you should be pulling a few more RPMs. What are you shifting at? When it lays down are you higher up in the RPMs or is it coming on early? Do you have a fuel pressure gauge? I think that is what I'd be watching next pass.
Re: Bored with 660hp.... [Re: Mr.Yuck] #1687900
10/21/14 10:09 AM
10/21/14 10:09 AM
Time after time year after year we see deals like this--it always comes down to throttle blades 3/4 way open - lash way too tight is a good one ( you see--these modern computer created crap lobes with inverse radius etc have the lowest spot on the cam somewhere other than the back of the base circle--Surprise!! )-7 volts to fuel pump, 7 elbows in fuel system, WRONG converter, etc
It is a rare day when it is the cam.
Had a 500 inch running 5.50's right off the dyno--three weeks later running 5.90's after the customer replaced a ton of parts he got mad and sold it--one week later in similar car was running 5.50's again--Verdict--lash was too tight--simple as that
Check the simple basics--look at the data you have from your timeslips--the answer is there.
Page 2 of 4 1 2 3 4
