Re: Harland Sharp rockers and now low oilpressure...
[Re: TomsCharger70]
#2063086
04/27/16 11:40 PM
04/27/16 11:40 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
What side clearance are you setting the rockers at? Too much clearance will also drop oil pressure. I shoot for 0.015 inches and make sure a 0.020 inch shim don't fit. I use a u shaped SS shim.
[Re: TomsCharger70]
#2798863
07/20/20 10:28 AM
07/20/20 10:28 AM
Posts: 1 Warren, MI
Miszny
Warren, MI
Thanks for this helpful thread, I did the same thing using jets... Wanted to bring pressure from 20 in gear to 35 with 20w50 oil. Turned out that 69 jet was perfect fit.
