Harland Sharp rockers and now low oilpressure...
#1687800
10/19/14 02:15 PM
10/19/14 02:15 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
Put Harland Sharp roller rockers # S70016K in my Indy EZ 295 head engine. Now problem is low oil pressure with engine running at idle, normal temp. The gauge shows just 5 Psi of pressure at idle, the oil pressure does go up instantly with Rpm, but I dont like it that its that low at idle... Car is a street/strip car... I run 5W30 Gulf MAX Supreme oil. Run a Milodon external oil system, Melling HV pump. -Am I beeing paranoid about the oil pressure at idle? If not -How can I get a little more oil pressure at idle? Thanks /Tom
Re: Harland Sharp rockers and now low oilpressure...
[Re: Clanton]
#1687803
10/19/14 02:41 PM
10/19/14 02:41 PM
TomsCharger70
Stockholm, Sweden
Their webpage says:"Oil restrictors may be necessary to maintain oil pressure." http://www.harlandsharp.com/bb_mopar.htm
-Yes, Thank You, I also read this. Problem is they dont tell how, what kind, where, etc.. to put the restrictors...
You can put a Mig welding tip in the rocker stand to help with oil psi.drill the tip to .060 to .100 and cut it to 1/2" and slip it in the rear rocker stand before you put the stud or bolt in and it holds the mig tip in.Done.
Thanks, this is the kind of info Im looking for?
Any one else have a solution, please post it, if you have pics, post them to...
/Tom
[Re: TomsCharger70]
#1687804
10/19/14 02:54 PM
10/19/14 02:54 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
/Tom
That would be the easiest solution , you need to put something in there to restrict the flow ... but this isn't a stock iron head , Indy's oil differently ...
Nevermind ...
[Re: TomsCharger70]
#1687805
10/19/14 02:55 PM
10/19/14 02:55 PM
TomsCharger70
Stockholm, Sweden
Looked at the Indy Cylinder Head page.. Found a Head oil restrictor kit # 440-R4-10R.
Any one use this kit? How does it work and how/where do you instal the restrictors? Who sells it?
Also the Indy EZ 295 Heads I have, have the external oil lines, could one put a restrictor in the oil lines going into the heads?
Thanks /Tom
[Re: TomsCharger70]
#1687807
10/19/14 04:05 PM
10/19/14 04:05 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
I drill and tap(6x32) the NPT end of the fitting that goes into the heads(both sides ) and screw a 6x32 brass set screw and drill it to .039 Works good and last along time
[Re: B G Racing]
#1687809
10/19/14 07:14 PM
10/19/14 07:14 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
With the Indy-1 and SR head external oil kit if used you can tap the inside of the brass fittings for Holly jets and use .052 to .075 jet sizes to restrict the oil.HS and other rockers that use the needle rollers on the shafts tend to bleed more oil.
In my opinion, this is the best, easiest and simplest solution. Been doing it like this for a long time, always works, and is easy to adjust to your liking....
RIP Monte Smith
[Re: B G Racing]
#1687810
10/19/14 08:33 PM
10/19/14 08:33 PM
TomsCharger70
Stockholm, Sweden
Does any one have a pic on how to do this mod? Sounds simple but im kinda a so one or two pics would help alot!
Thanks /Tom
[Re: PLUM BAD]
#1687813
10/20/14 02:19 AM
10/20/14 02:19 AM
Posts: 5,161 CT
GTX MATT
CT
Out of curiosity what was the net change in oil pressure?
[Re: GTX MATT]
#1687814
10/20/14 06:19 AM
10/20/14 06:19 AM
TomsCharger70
Stockholm, Sweden
Thank You for the pics!!! GTX Matt* The oil pressure went down from about 20 psi at idle to 5 psi after the rocker change (engine at running temp). Engine idle is set at 1000rpm. /Tom
[Re: B G Racing]
#1687816
10/20/14 06:56 PM
10/20/14 06:56 PM
TomsCharger70
Stockholm, Sweden
This seems the most simple way. If I start to mess with the small brass screws Ill probably just end up and
At idle wouldnt some 10-15 Psi of oil pressure be more than enough???
Thanks again!!! /Tom
