Big Tire Cars #1686417
10/16/14 11:48 AM
10/16/14 11:48 AM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I've been having an argument with a guy I work with. So please chime in.....
Is there such a thing as "Too much tire"?
If there is, what are the key things to look for?
Thanks for playing
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Big Tire Cars [Re: 1320Dart] #1686418
10/16/14 12:35 PM
10/16/14 12:35 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Ya,if its a 10 or 11 sec car,there's no need to run a 14 X 32 tire. In reality its probably slowing the car down.
Re: Big Tire Cars [Re: OUTLAWSSAA] #1686419
10/16/14 12:45 PM
10/16/14 12:45 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Definitely, I know this SS/KA car shaved off considerable ET by simply going from a 14x32 radial slick to a 10.5x30 radial slick
Re: Big Tire Cars [Re: 496 A-body] #1686420
10/16/14 01:09 PM
10/16/14 01:09 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
How did you know it wanted a smaller tire?
Greg
Re: Big Tire Cars [Re: 1320Dart] #1686421
10/16/14 01:17 PM
10/16/14 01:17 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Depends on what you are trying to do. I know some very successful bracket racers who run huge tires on realitively slow cars just for consistancy.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Big Tire Cars [Re: 1320Dart] #1686422
10/16/14 01:59 PM
10/16/14 01:59 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I'm guessing because the car is not mine but belongs to the father of a friend, but I'd say it seemed logical, a car that runs 10.40s combined with the minimal torque output of the 283 a 14x32 seems like overkill, his son also runs a 283 powered car in Super Stock and runs a 9x30 radial slick despite having a back halved car and class rules allowing a much bigger tire to be used. Leaves the line at 7k and still prefers the small tire.
Re: Big Tire Cars [Re: 496 A-body] #1686423
10/16/14 02:21 PM
10/16/14 02:21 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
This could be because he went to a smaller diameter tire. But, I would agree if the tire is lighter it will help.
Re: Big Tire Cars [Re: Dodgeguy101] #1686424
10/16/14 02:27 PM
10/16/14 02:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Very much agreed that it depends on the application. If it is a bracket car I would say NO. If it is in the case of looking for every last little .01 then yes you can easily have WAY more tire than needed. But I don't think you are building a heads up car so IMO use what works best most consistently.
Re: Big Tire Cars [Re: Dodgeguy101] #1686425
10/16/14 02:29 PM
10/16/14 02:29 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Good point about the diameter! Shortly after making the change in tire size he went from a dana 60 to a 12 bolt, not sure but he may have changed gear ratio to keep his RPMs where he wanted them.
Re: Big Tire Cars [Re: Al_Alguire] #1686426
10/16/14 03:15 PM
10/16/14 03:15 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I guess I was wrong then.
I was arguing that there is such a thing as "too much tire" for a car.
Greg
Re: Big Tire Cars [Re: 1320Dart] #1686427
10/16/14 04:07 PM
10/16/14 04:07 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
larger tires simply weigh more and have more friction. Same basic reason to have skinny tires up front to reduce rotational mass and friction at the top end. My 2 cents on the subject.
Re: Big Tire Cars [Re: 80fbody] #1686428
10/16/14 04:48 PM
10/16/14 04:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You only need enough contact patch to stick the supplied torque on a consistent basis. Anything beyond that is dead weight to pull. WAY too many guys put more tire on their cars than they need as a crutch for a poor working chassis.
Lots of bracket guys are among the "stick and go" persuasion......meaning put a big enough tire on there that you pretty much dead hook it, regardless of track conditions and never have to worry about wheel spin. That's fine if that is the route you want to go, but even at that, if a 14x32 will get the job done, a bigger tire won't help it hook any better and will only slow the car
Now where some of this goes completely out the window, is cars with a LOT of power. Many of these cars will NOT work with the tire dead hooked. They want to shake. In those instances there is definitely a such thing as too much tire
Monte
Re: Big Tire Cars [Re: Monte_Smith] #1686429
10/16/14 05:06 PM
10/16/14 05:06 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Hi Monte-
This is what I was trying to argue.
Was what you said here:
"They want to shake. In those instances there is definitely a such thing as too much tire."
But I thought that blanket rule for all cars. So that's where I went wrong on my argument
Greg
Re: Big Tire Cars [Re: 1320Dart] #1686430
10/16/14 06:17 PM
10/16/14 06:17 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Hi Monte-
Nine times out of ten, if you are "shaking" the tire......you are underpowering the tire
Monte
Re: Big Tire Cars [Re: Monte_Smith] #1686431
10/16/14 07:49 PM
10/16/14 07:49 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yup...I have big tires....And I am slow....Oooh, and I won the Modified Gasser championship last year.
So if your a bracket racer, it may slow you down if they are bigger than you need, but the track is not always perfect either.
What I don't have to do is adjust the suspension for evey little track imperfection or changing conditions...I do make changes to it, but generally once its set-up, it hooks.
I drove a 600hp small tire car a couple years ago....Doing a Ssss down the track is not my idea of racing. Nor did I feel very safe staying in the throttle....
Re: Big Tire Cars [Re: Eric] #1686432
10/16/14 07:52 PM
10/16/14 07:52 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Depends on what you are trying to do. I know some very successful bracket racers who run huge tires on relatively slow cars just for consistency.
the answer
Re: Big Tire Cars [Re: jamesc] #1686433
10/16/14 08:17 PM
10/16/14 08:17 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
easy formula,divide the tire width by your i.q. if the answer is less than 2 you should be racing the"short bus"and licking the windows as you pass the 60 ft mark......
SFI 25.5 depends,no leak,even at 213 mph....
Re: Big Tire Cars [Re: dakotawilly] #1686434
10/17/14 12:19 AM
10/17/14 12:19 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I bracket race my 9.20 foot brake car in pro and N/SS on a 10.5x29.5. It was in the winners circle 3 times this year, 2 semi-finals in 12 outings. Spin is not a problem.
Doug
Re: Big Tire Cars [Re: dakotawilly] #1686435
10/17/14 01:11 AM
10/17/14 01:11 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
well everybody will be on the short bus with that formula unless we use millimeters for width.
Re: Big Tire Cars [Re: dakotawilly] #1686436
10/17/14 01:24 AM
10/17/14 01:24 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
That doesn't make sense. Baseline: Average IQ is 100. Untubbed duster fits a 275 tire. So that gets you a 2.75- safely above window licker status. A super genius should be able to make a skinny tire hook by controlling the power delivery and instant center but his 150 IQ gets him a 1.83 score- his favorite color is 'clear'= window licker.
