65 Satellite belt molding trim clips??
#1685757
10/14/14 03:20 PM
10/14/14 03:20 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I just parted out a 65 Satellite and a while back a 65 Coronet. On the doors and the 1/4 panels where the narrow trim clips on below the stainless trim at the top of the door and 1/4 panel are these the correct clips that were used? Are they available aftermarket anywhere? I see the trim clips for a 68-70 B Body vinyl top trim are nearly identical. Can anyone confirm the total needed to do both doors and 1/4 panels? (I think I count 26) I have a guy who wants a set and I may have trouble coming up with a complete set.
Edited to say Satellite instead of Coronet.
...FAFO...
Re: 65 Coronet belt molding trim clips??
[Re: skicker]
#1685758
10/14/14 05:09 PM
10/14/14 05:09 PM
skicker
"The Champ"
"The Champ"
Western Md.
Picture of clip in question.
...FAFO...
[Re: Part_Stalker]
#1685760
10/14/14 07:50 PM
10/14/14 07:50 PM
skicker
"The Champ"
"The Champ"
Western Md.
When I parted out the Coronet it had never been painted so I assumed it had never been apart. The Satellite I just pulled apart was painted years and years ago and had these clips. Did they use both types or has someone changed these out on two separate cars?? Ist car came out of NY and the other about 70 mile away. I think I have an old Satellite door in storage. maybe I can go see what it has. Could it be a Plymouth or Dodge thing?
...FAFO...
[Re: Part_Stalker]
#1685762
10/14/14 11:26 PM
10/14/14 11:26 PM
skicker
"The Champ"
"The Champ"
Western Md.
I had it as Coronet 440 but I looked at the 440 in the garage and it only has the top trim (belt molding) which does use the clips like pictured only a different width. I was thinking it was a 440 model that had the trim the same as a Satellite. Ultimately what I am looking for is whatever clips would be used to install the belt molding trim on a 65 Satellite. I pulled out a few different pieces of Satellite trim I have here and two sets used the steel clips while one piece had the plastic clip still in it? I will post pics of those tomorrow.
...FAFO...
[Re: Part_Stalker]
#1685771
10/15/14 01:04 PM
10/15/14 01:04 PM
skicker
"The Champ"
"The Champ"
Western Md.
I have purchased a few things from him in the past and always got very nice stuff.
...FAFO...
[Re: skicker]
#1685772
11/06/14 07:02 PM
11/06/14 07:02 PM
Posts: 219 Ontario Canada
300_dup5
Ontario Canada
Just got some Parts from Skicker nice guy Helped me out with some small stuff for my 65 Satelitte, Those Belt moulding clips, Skicker sent me one of the steel ones( yes some had plastic, some steel, matched them up with 68-70 b body vinyl trim clips, almost identical
[Re: 300_dup5]
#1685773
11/07/14 10:29 AM
11/07/14 10:29 AM
skicker
"The Champ"
"The Champ"
Western Md.
Glad you got it figured out. Work out all the bugs on yours, then once you know how everything goes back together you can come down and do mine.
...FAFO...
